Stove ignitor mod
Tradmonkey
Apr 7, 2010
13
San Diego, CA
Hey all, new to the WTW forum here, and a new owner of a '94 FWC Ranger II. The stove in it had no ignitor, and while wandering the aisles of Wal-Mart the other day, I came across this little gadget. Robot or human? It's a AA battery powered push button ignitor for a gas grill. Perfect, I thought. That would have to work for the stove in my camper.
So I threw it in the cart, and tonight I installed the unit. The verdict? It works like a charm. See for yourself...
[media]
Installation was fairly simple.
Here's a view of the stove prior to installation.
And here's the ignitor out of the packaging.
First step was to figure out if everything would fit where it would need to. A quick inspection confirmed that there would be no issues.
I decided the best location for the push button for the ignitor was right above the utensil drawer. That would put it right in front of the stove knobs and give me easy access by simply removing the drawer. I drilled the 7/8" hole after some careful measurements to confirm everything would fit, and then tested the installation of the ignitor power unit.
The fit was close, but the threaded portion of the ignitor power unit was just a tad too short (or the wood was too thick) for the threads in the push button cover to reach. To solve that problem, I simply cut the flange off of the outer edge of the push button cover and slightly countersunk the hole in the wood.
Voila... now everything fits.
The ignitor has three leads coming from it - two for the electrodes and one for the ground. Rather than drilling an additional hole, I used one of the existing screws from the stove control knob dial plate mounts.
Next up, installing the ignitor electrodes. I selected hole locations where the electrode wires were least likely to be exposed to excessive heat, and where the under-side of the electrodes would have clearance away from gas lines, and drilled.
Ok, everything looks good, now for a functional test. We have a spark!
With everything put back together, the gas gets turned on and the real test begins.
SSsssssss... the gas begins to hiss. Click Click Click Click... sparks are popping, but nothing's igniting. Crap! A quick test with a lighter shows that gas is indeed flowing from the burners, but the spark isn't igniting it. Careful inspection reveals the spark is hitting each burner about 1/16" above the fuel ports in the burner. Hmmm... A quick adjustment of the electrode tips puts the spark right into the fuel flow, and on the next test, the burners light instantly with the first click of the ignitor. Sweet!
So now I've got an electric ignitor for my stove. One mod down, countless more to go...
Adam
Good deal, much smoother than messing around with a lighter. I've got push button on mine and like the ease.
Welcome. I have been frustrated with having to light the stove for years. I tried a push sparker but it didn't work well. I'm excited to try this fix and my wife will be thrilled. Excellent video and how to pictures. Pro quality.
Very nice mod, the pictures are worth the price of admission! Welcome
Great find. I just installed the auto-relighter on the frig. Now I need to go for the stove. Thanks for the write up.
Very nice idea. Placed an order already. Besides my stove I'm wondering if I could make it work on my coleman stove and my hot water heater and and, wait, I think thats all. Imagine going matchless (lighterless).
But then what would I use for my crack pipe?:LOL:
The relighter used for the fridge works great for the water heater too.
welcome and thanks for the tip.this forum is soo cool what would we do without it for our mod sharing.i think i will give these a try.the wife has some trouble with the lighters.this will solve the problem.thanks again. frank
I just got my ignitor for my stove and put in it. It works great! Her are a few pictures.
I just got my re-lighter for my stove and put in it. It works great! Her are a few pictures.
Just for clarification this is an ignitor, not actually a re-lighter. I just wanted to clarify its different than the re-lighter mod we're putting on the fridges which sense the flame is out and re-spark it automatically. Just don't want someone confusing the two.
Hope you enjoy the mod!
My bad I fixed it :(
Installation complete. Can I make a simple project complex? You bet. Drilled a 7/8ths hole in the wood below the stove. Changed my mind and installed the ignitor in the stove. If you do this make sure you have a 7/8ths hole saw. Guess what? With the cover closed the ignitor goes off. Had to make some stand offs. That wasn't bad, found some stuff in the garage and glued em down.
Be careful, those connections are fragile. I broke one off at the ignitor and another at the rod. /sigh Do I get another kit so I can use both burners? We'll see. Watch the placement of the rod. Keep it close. I had to move the burner slightly so it was close enough. Easier to shorten it if you wind up too close. Only zapped myself once.
OOh you just made me crack up :LOL: Lets see some pic's
Try RV Life Pro Today
