Tire question and spring/air bag question
randygirl
Sep 9, 2010
170
SW Florida
I have been reading this forum like mad the last week or so and am getting more anxious then ever to hit the rosd. I have graduated from traveling in a VW camper for the last 13 years to getting a 2004 Toyota Tundra 4x4 and plan to get a Hawk from FWC.
My question is in what I need to do to the truck. Being a girl(which is no excuse, but I'm not as up on suspension as some of the guys might be!!) I am confused about 2 things. I went to the tire place to price the load range "E" tires and he could not find anyone who makes them in a 265 70 R16. Only 265 75 R16. He will not put the 75's on my truck because Toyota says max size is 70... He can get me a "D" load in my size though.. Would the "D" load work or is it OK to go to the 75's??
I also plan to use the hellwig springs.. I have no clue what shocks are on the truck. I am afraid of the air bags cause of leakage and not having air with me. Should that be sufficient to start out with? I know no one can tell me what I will be comfortable with, but I am having a hard time finding a place to start. I live in Florida and am not finding many folks around here to answer my questions...
I have already learned a ton from reading all the message boards on here, so I am really hoping someone could help me out.
Also my truck had the trd off road package if that makes a difference.
Thanks for your help
There are Tundra owners here that will be able to tell you what they use but I'm pretty certain you can get an E rated tire for your Tundra. If you are never going to take the camper off (or very rarely), new springs are better but if you plan on taking the camper off and using the truck as a daily driver, you'd be better off with the airbags. The airbags don't leak much and even if they do its not a life or death situation. A small 12v air compressor isn't very expensive and can be used to air up your bags if you need to. As for shocks - I'd go with some aftermarket gas shocks as they aren't very expensive and they will improve the ride with the camper a fair amount.
Thanks DD for the quick response.
I see most folks are using Bilstein 5100's for the shocks. Would I put them front and back??
I will have the camper on for the summers for traveling(6-7 months) and off most of the winter for being home(5-6 months, with the occasional weekend trip). I guess that is why I am more leaning towards the Hellwig springs, but still really not sure which is best for my situation.
Does anyone run their Tundra "stock" with a FWC/ATC on it?
Yeah you'd use the shocks front and back. I know this is all new and somewhat confusing, but airbags really aren't something to be afraid of.
I just looked at some pictures of the Ride Rites mounted and they do look nice and not as scary!!
I guess that part is figured out... Now if someone could help with the tire question...
Thanks
It was a Firestone I went to. He said someplace would sell me "E" range tires at 265 75 r16, but since my trucks specs are for 265 70 r16 he would not. He said going from 70 to 75 would change the stability and handling of the truck.
I was not exactly sure what difference going from 70 to 75 would make, so I thought I would ask in here. I don't want to cause a rollover or nothing!!
Hi RG,
Welcome to the forum. My very first vehicle was a vw camper, so I feel related to you. :)
We have a 2000 Tundra, so the specs may be different, but we run BF Goodrich All Terrain 265 75 R16's and wouldn't buy anything else. There is no problem as far as rubbing or anything like that. To go with a larger size may cause such problems. You may want to check out a website called Tundra Solutions as well (sorry DD, but I did just put a similar message directing someone to WTW on ExPo). There are literally thousands of people on that website that have done every modification possible to Tundras. They could tell you for sure.
Being a girl
You are right. That is no excuse and nothing to be excused for. My wife has taken our camper out solo when she wants to do a trip and I can't join her. Get out and enjoy!
I have to second the ease of air bags, I carry both a small 12V compressor and a floor style bike pump and use the bike pump most of the time. Best of luck on your camper search.
Thanks so much for the replies.
@Magellan: I didn't think that the 75's would make a huge difference, but I was not sure. Heck, I'm not even sure how much of a difference there is between 70's and 75's. I would go out there alone, but I just am not as knowledgable on car type stuff.
Any Tundra owners out there???? What tires do you have?? ( mine is a '04 access cab)
Randygirl
Randygirl
Randygirl,
As Ted says run the 265/75/16's, I ran two sets (D & E rated) on my 06 Tundra double cab before I switched to 285's and a lift, you will have no issues with fit. I also recommend the BFGs as Ted says. As for airbags I use the Firestone's too and have really beat the crap out of them over the years, so as others have said, don't let them scare you....they are tougher than anything you are likely going to put your truck through. And as Dirty Dog says, if the camper is going to be permanent, the springs might be a better (and cheaper) option. Good luck.
Thanks everyone.
I think I have decided to get the ride rite air bags and the 265/75/r16 "E" tires. I'm not sure if I'm getting michelin or BF Goodrich A/T.
I will probably wait on the shocks and see how she rides. There are Bilsteins on there cause of the TRD off road package, so I'm hoping those are OK...
I will keep reading and be sure to come to youo with any more questions...
Anyone want to buy a VW van??? (hahaha)
Randygirl
Thanks everyone.
Randygirl
I've had enough sets of BFG AT (and AT/KO) tires on 4 different trucks that I have lost count, and I think they are one of the best all terrain tires available. A camping friend of mine swears by the Michelin's for many of the same reasons that I like the BFG's (long tread life, smooth ride, good traction). We have travelled together over some incredibly fun terrain. I will need new tires soon, and both BFG and Michelin are on my short list. I think you'll be happy with either tire.
I see that you're in SW Florida, which is about as far away from me as possible and still be in the USA. Maybe, if that VW is a Vanagon, Westfalia, Syncro???
ED,
The van is a 1989 Vanagon camper. It is the GL model (westfalia). My email is crookbull@gmail.com
I really need to sell it for some $$ for the camper. It will probably cover the down payment!!
I found a few used campers but they are all in Cal and I cannot drive out there and get them.. FWC will deliver mine to North Florida. A one day drive. I need to work these next 6 months to save $$ for the trip! I am excited to get a new camper too. Only new thing I'll have ever owned!
Email and I can send pics!
Randygirl
Oh yeah,
I willprice Michelins and BFG's and I guess the most affordable willwin. Should I get them now while Sears is having a sale? or wait till it gets closer to getting the camper ?? (I'll probably get it in delivered in Jan)Will it make my ride real rough around town??
You guys are most helpful!!!
I know way more than any woman I know about tires, shocks, brakes, and air bags!!! When I ask guys I know they look at me like "How do you know more than me??" It is pretty funny!
