Torklift Stableload spacer setup for Tacoma / Fleet?
Double Alpenglow
Oct 29, 2017
6
For those with the stableloads, how many spacers did you use? I have a 2017 Tacoma, but information on the older gens will still be useful.
How many washers? Front and back?
How wedges? 2 or 3?
Thanks!
I installed them and back from the first 4wd trip.
-2 wedges
-5 washers front and back
2 wedges seems fine. It gained another 3/4" of wheel well height on top of what it gained from sumosprings 1000lb bump stops. It's almost level now. Also have the Bilstein 5100's. Overall I'm really happy with the handling now. Has anyone tried 3 wedges?
Install notes:
-The front holes need to be drilled about 7/8", not the stated 1". Use the Stableload assembly to mark the hole. Other wise it will interfere with the leafspring U-retainer
-I had to move the brake line bracket up an inch or so. Just need to drill and tap a new hole higher on the leaf spring U-retainer. It will make sense when you try to install them.
