Truck Battery Question
ExplOregon
Mar 24, 2019
27
Beaverton, OR
Hey All,
Long time lurker. Excited to be joining the community.
Background Info:
Truck: '09 Ford F150 XLT
Camper: '18 FWC Hawk Shell with propane heater and fantastic fan and single stock FWC house battery (Arrives 5/2/19ish)
Here's my question:
I'm prepping the truck for the arrival of the camper (going through 10/40 Overland out of Beaverton, OR for the order). The battery in the truck is on its way out so I need a new one. The question is what type of battery should I get (starting or multi-purpose)? I've been searching the Ultimate Battery Thread and other threads on WTW, but haven't found much info specially on recommendations for truck batteries. Maybe I should just replace the OEM battery with something similar, but thought I'd ask the question here just in case the community has other thoughts.
Additional considerations:
  1. I plan to mount solar panels on the roof within a year or so
  2. I'm considering adding a winch and lightest possible bumper to mount it
  3. I plan to mount some additional lighting sources (light bars, etc) for driving while off-road
  4. Depending on power needs, I would consider adding a second house battery if needed
  5. I plan on adding a Noco Genius Charger + Plug to help maintain the house battery while not adventuring
Thanks for any advice/thoughts/recommendations. I'm a newbie so still trying to figure out how this all fits together.
buy your truck battery assuming there is no camper. they serve very different functions. i like optima yellow tops for start duties
Since a winch is list as #2...I've been a Warn winch fan since the 70s. Never had one fail or let me down. Having said that...
Visit a 4WD center and have your alternator tested for condition/performance since your truck is 10 years old. The winch is a huge current draw, especially when you get into the 10K# units. While the winch connects to the battery terminals, you winch with the engine running so the alternator provides current through the battery to the winch.
As such, any degradation in the alternator's output will put the crank battery into a state of discharge. I would buy the largest (CCA/C20) battery that will fit in the truck. I like Interstate crank batteries but have used Optimas as well.
Mounting the winch can be tricky when you look to light-weight winch bumpers. You can't afford to have any deflection in the bumper when winching, not only can this lead to catastrophic failure of the bumper but pose a huge safety hazard to any nearby human or animal. If up-front weight is an issue, consider a winch tray mounted directly to the frame. A winch tray does not replace a bumper for highway safety purposes so check your state regulations.
When using a light-weight mount for the winch, pay particular attention to straight-line pull specifications and try to avoid more then a few degrees off a straight pull. Weight capacity for off straight line pulls is not linear, so tough to guesstimate what you can get away with before the winch mount fails.
I have a PNW friend with a Hawk shell. He did a great deal of research before up-fitting his shell. He is using 1 house battery with 1 roof mounted panel and 1 portable panel. Every installed component in the shell was given consideration for limiting power draw and battery drain. It's a very nice setup with all the comforts I have in my factory optioned Hawk yet with a weight savings of nearly 400# (less wood/cabinets) and substantially less energy requirements than my Hawk. He is using a diesel heater/blower and National Luna frig; tremendous energy savings due to operational efficiency and design compared to factory installed components.
Up-fitting a shell can be a fun project. Enjoy!
I put a Deka Intimidator AGM in my Tundra. No issues whatsoever with it, ever. I also ran the same battery in my old Xterra. If/when I need another battery it will be the same one.
To echo Vic, I say keep the truck and camper battery different types, in keeping with their different functions. Engine starting should be the #1 priority, IMO. So something at least as capable as the oem truck battery.
A winch gives more reason to go with a SLI / cranking type battery (and biggest) and perhaps large gauge wires to the house battery for winching (and starting assist). That's what I did, plus I went with "marine" house batteries as a sort of dual purpose type. But like many folks didn't use much if at all so switched to a deep cycle for house but the larger gauge can still be useful.
Offroad lights should be supplied by the alternator, in most cases.
If you were charging the house exclusively with the alternator and had room for a larger or dual truck battery then I'd consider matching truck and house types.
Also, I hate corrosion of terminals and wiring from off gassing and electrolyte shaken out of vent caps from rough travel so I'd look at buying AGM replacement for the truck. Even better if the voltage charge profile matched the house battery, so I'd find out what model is to be supplied by FWC and check the charging specs against what you might buy for the truck.
PS Welcome to WTW
... and enjoy your camper !
Thanks Everyone! Appreciate all the feedback. I don't think that I'll realistically get a winch at this point so that should make things a little easier for me.
Regarding the Optima Yellow Tops, I have some additional questions:
  1. The Yellowtops for my truck require 2 blue group 65 bottom snap-on adapters, but none of the shops that I called (AutoZone, O'Reillys, etc) had any idea what I was talking about or knew anything about these adapters. Therefore, do I really need these adapters or can I rig a different solution? Or how do I get my hands on these adapters? Do I need to call Optima?
  2. There's been some chatter recently on other forums regarding the Optima's quality declining after moving their factory to Mexico. Any truth to those claims?
I'm considering the Duralast Platinum AGM as an alternative. Close to OEM fitment, cheaper price (than YTs), good reviews, 750 CCA and 935 CA. My current OEM Motorcraft battery is 540 CCA.
Check with Mike's Auto Parts in Cedar Mill close to Roth's IGA. I have bought several Optima batteries and Noco chargers from them. I wanted a matched pair of Blud Top Optimas for my boat and he got very recent ones with serial numbers 20 units apart for me. I also bougjt a Yellow Top Optima for my Tundra. He has you write the purchase date and register sequence number on the top of the battery so that it can verified for warranty quickly if needed from their records. They were competitive in price, quick in getting what I needed and great customer seervice. They seem to do a lot of RV electrical stuff and carry several battery brands.
According to Mike's the Made in Mexico problem was real after they first started manufacturing there some years ago but they pulled it back to the US, at least, to get the quality back.
They used to come with the adapters. Not sure if they still do. I sure hope the quality issues are a thing of the past. The ones in my Jeep are holding up well. Getting near time for new batteries in the truck. Starting to look around.
Without a winch or similar need, you don't really need a more capable battery. I'd then put reliability and value at the top.
I'll just throw this in about brands.
If your oem is the original at 10 years old and has performed satisfactorily up until recently. That, imo, speaks pretty well about the Motorcraft brand. I've had good service out of mine (10 or more yrs, 2 diff vehicles). Maybe that is common with other oems, I can't say.
I don't see AGM mentioned in this info but they do have a number of grades including the BXT series that appears to meet the specs and perhaps exceed the warranty of the Duroplast and also may be cheaper. And you never know with Parts at a Ford dealer, competitive times may have changed their pricing.
Lot's of choices out there and you may want something specific for your own reasons. Just wanted to mention that Ford sells/supplies a large number of batteries each year and has done so for many decades. Not sexy but I haven't heard much bad about their batteries.
@PaulT - Unfortunately Mike's Auto has closed. I grew up right down the street from the shop. Best customer service around! Hopefully he's just moving to a new location. They tore down that whole shopping center and are putting in new shops. Bummer cause I could have used his help with the Noco charger as well.
In the end, I went with the Duralast Platinum AGM. We'll see how it goes. For the record, when I went into Autozone, they did have the adaptors for the YellowTops even though when I called them earlier in the week they said that they didn't. Hopefully, the Platinums are somewhere in the middle btw OEM and YTs. We'll see.
Thanks again everyone!
FWIW I bought the spacer/adapter that most Optima's need off Amazon when I put a blue top in our 4rnnr.
This battery spent the first 3 years of it's life in a large battery bank used for testing contactors. When I put it into the truck my SB-300 battery tester said it had 930 CCA, well above it's rated 750 CCA.
Now that I've started pricing batteries I'm a little surprised to see starting batteries priced as high as deep cycle batteries. I don't recall it being that way in the past.
I was going to say I remember when your local auto parts store had $35 batteries sitting on the shelf but then I realized I'd have to move that to the geezer thread :)
Latest posts
