Truck front sway(stabilizer) bar links
buckland
Jul 26, 2011
3,095
New England
Thought I'd ask if anyone has a source for purchasing a more robust sway bar link? Yup one of mine broke at the end. I have found the OEM ones but if I could find a better one for a bit more why not!?
Thanks in advance for any thoughts.
Thanks Vic, I actually was searching on that page before and those trucks all have lifts, I did not replace my links when I put on Bilstein shocks in 2016. I was hoping to find similar to OEM but tougher. There are so many out there and almost all made in China. Not sure of what quality it is. Thanks for the effort!
Thanks Vic for the recommendations...I'll check out both those. Steve I have the Hellwig sway bar on the rear but I did not know if they make parts for the front as all i need are the two end links nt the whole bar...but I'll definitely check all these. Appreciated.
Rob
Hey Vic ... a big shout out thanks to you. Even though their website Cognito said they did not have them for the Colorado, I called CarID and gave them Vin# and as their website said it fits! They checked with the tech dept and they also said yes. I sure hope so. They are twice the price but look very robust (USA made) and same design as for the HD GM trucks.
Rob
Putting on my troll hat. I wish we could get away from the term sway bar, which it really isn't. It's an anti-roll bar—which is admittedly an awkward term besides the potential for confusing it with a roll bar. Stabilizer bar would be a nice compromise.
Troll hat removed.
I agree... when first heard the term I was confused... my mechanic calls it a stabilizer ... I can use as much stabilizing as I can get!
JHanson,
Agreed.
Indeed it is not a sway bar. Stabilizer bar, anti-roll bar or even anti-sway bar are better descriptors.
rant off.
Craig
JHanson,
After adding new, somewhat softer, 2" over stock Deaver leaf springs to my tuck front and rear I found that with the camper on the truck it led to unsafe roll in turns which caused oversteer in a turn at speeds over about 45 mph which then led to sway (or oversteer left and right - nose dives into turn and rear end tries to come around) from trying to correct with steering input. At highway speed it led on one occasion to a back and forth roll and oversteering correction until I bled off speed - frightening.
I took the truck back to Deaver and Jeff added another leaf to the rear springs and stiffened things up a bit. That made the situation much better, He said if that didn't solve the roll issue that I I should add an anti-sway bar (anti-roll bar).
After the leaf addition the truck was still rolling too much in turns for my comfort so I added an ADDCO stabilizer bar (anti-roll bar) to the rear. I would have preferred Hellweg but they no longer make one for my old truck. The rolling is no longer a problem but that left me with an annoying wander in the steering that was not as noticeable previously.
I had previously replaced all the tie rod ends and had the bearings and front u-joints serviced which left only the steering box as a potential suspect. I evaluated the steering box and found that it had too much play so after reading a lot of reviews about problems with Redhead steering boxes I replaced it with a Bluetop steering box. It still has more play than the original steering box had when new and well into its life, indeed the truck handled like it ran on rails until it had over 325,000 miles on it, but the Bluetop unit is within the spec limits so not returnable.
Bottom line; Adding lifted height springs coupled with changing the spring stiffness can lead to unintended consequences. The roll and resulting sway are gone but I still have a little bit of steering play which leads to a small amount of wander within a lane width, particularly on uneven pavement. It is annoying but not particularly unsafe in my opinion.
Shocks are new Bilstein 51xx series all around.
JHanson said:
For those wondering, there's a good explanation here. The anti-roll bar controls roll; it has no effect on sway.
That's brilliant. I can't really see "sway" happening too often in a pop-top, as sway would have to be induced by outside forces, like a side wind gust. In a towing situation, the trailer could also add a lot of side loads. Or am I missing something?
Bing Videos
Latest posts
