Bill D
Here's a tip to make reinstalling your turnbuckles MUCH easier.
No more fumbling around in a confined space.
Label them DF, DR, PF, PR
This will allow you to:
-remember which location you removed them from. You will only need to tighten them 1/2 turn or so to get them to a point where they don't keep falling off the eyebolts as you tighten them.
-You know which end is the top and which end is the bottom.
When placing your label make sure that rotating in a clockwise fashion tightens the buckle and counterclockwise loosens the buckle.
