nocruisecontrol
- Joined
- Feb 19, 2018
- Messages
- 4
Hello! Forgive me if this topic is buried deep in the forum here, I have searched many threads without finding an answer.
I have a 2001 Eagle. The water tank display lights up like it is getting power, does not make any noises whatsoever. The camper sat for what I suspect is several years prior to me getting it. I’ve come to terms that I should just replace the water pump and have piece of mind, since we will be moving into the camper full time. My questions are 1) how do you gain access to the pump? From what I can see, it looks like I may need to remove the countertop. 2) What are others using for filters? I have seen some pumps with built in filters, inline, perhaps faucet filters? Looking for a particle and UV light or other purifier. Curious what others are using. 3) I am planning on calling FWC for a new pump, unless anyone has a better aftermarket solution. I also thought this would be a good time to look over all the water lines, and replace if necessary.
Thanks for the help!
