New Outfitter Juno 10
nobueno
Oct 22, 2014
36
Already posted this at ExPo and rv.net but wanted to post here to help others find the info I couldn't when looking for a Juno.
I've been looking for an Outfitter Juno 10 and finally lucked out. Found a used 4 month old 2015 significantly discounted.
crB05wM.jpg%20height=480%20width=640
First, the good. The price. It was fairly dirty and well used in the 4 months the guy had it but it cleaned up nicely:
08Q71IC.jpg%20height=480%20width=640
lkqhSoZ.jpgheight=480%20width=640
EGTyYzE.jpg%20height=480%20width=640
Bo4ghRa.jpg%20height=480%20width=640
SyAccHR.jpg%20height=480%20width=640
bQHD9wI.jpg%20height=480%20width=640
H0T2cPr.jpg%20height=480%20width=640
pMgD2rR.jpg%20height=680%20width=480
aNFvanU.jpg%20height=680%20width=480
eywbr8b.jpg%20height=480%20width=640
5YUlPKg.jpg%20height=680%20width=480
T0hVIio.jpg%20height=480%20width=640
The extras he had installed: 300w solar, 2000w inverter, yakima racks, a/c, hide a bed, oven, 10' awning, all led lights, extra cabinet, 2 four gallon locking rotopax, outside speakers and outlets and a few others I'm probably forgetting. 430ah of battery life. 50gal of water capacity including water heater. The tent room was a must for our St Bernard:
hii45Xq.jpg%20height=480%20width=640
or two
PJP8C7r.jpg%20height=480%20width=640
or three
SfDC0jq.jpg%20height=480%20width=640
I love how they store the batteries. In our last camper they were on the outside of the camper and the temps would fluctuate too much. Outfitters system is much better. Stored under the dinette in a compartment vented to the outside. I was also glad to see they used 2/0 wire.
6r6xgpg.jpg%20height=480%20width=640
YYmYd48.jpg%20height=480%20width=640
The new construction is also nice. Molded sides from cabover to the back door where it meets up with the back section. You can see the seam here:
jqB9ecM.jpg%20height=480%20width=640
No seams along the rest of the camper:
RbuDz71.jpg%20height=480%20width=640
http://i.imgur.com/o5WmWCq.jpg height=480 width=640
The bad. He bumped a jack on a tree and caused a little damage to it. it was repaired at a shop and appears to be fine. I talked with the guys at Outfitter and they said that jack is backed by a steel plate so it shouldn't have caused any issues and worst case scenario, they could replace that panel for $500. He camped by the ocean and stored it by the ocean. There is quite a bit of rust in a few places already. Nothing too concerning but I hate rust. I'll just have to remove rust and repaint. Pics of jack damage and rust:
http://i.imgur.com/KUR0uDV.jpg height=680 width=480
http://i.imgur.com/UNa6cV1.jpg height=680 width=480
http://i.imgur.com/2TyFWF0.jpg height=480 width=640
jack back on
http://i.imgur.com/2PuQEiH.jpg height=640 width=480
He also had them add a spare tire mount on the roof but decided it was too heavy. I'll likely just remove it and seal up the holes. It's a big steel bracket that spans the width of the roof.
Only camped one night so far on my drive back to CO. It was windy but the walls didn't shake at all which i was happy about. I drove back in 40mph winds gusting to 60 almost the whole drive. It handled the wind better than I expected. It's nice to be able to access the dinette, oven and bathroom with the top down as well. We'll have it up in the mountains soon and I'll report back with more as well as an official weight once I get to the scales.
The way it was optioned it was 3000lb dry. Between that steel spare tire rack, A/C, extra cabinet, 3 solar panels, Yakima rack, etc. Once I have it set up how I want I'll get it weighed again and get a wet weight one of these days. I've got a payload of 4200 so I'll be alright but it's heavier than I was hoping.
Bob said a base model juno should weigh around 2300 dry and I'd say that's probably accurate. There's a lot of heavy extras on here.
Nice rig. Should serve you well. Really lightens up inside with all the windows open.
That tent room is perfect for the Saints (and their ring leader). Between them and the food you have to haul for them, better keep an eye on your GVW :unsure:
It is nice to see the details in the options and construction of an Outfitter. Thanks for sharing and we expect you are going to get years of enjoyment out of your rig. Happy camping! :)
yea, when we're all loaded i'm thinking we're going to be pushing gvw but as long as the tires are below their max load that's my primary concern. like i said i want to ditch some of the excess stuff and see what it comes in at. it is heavier than i was hoping. they put a 13.5k btu AC on the top that weighs 100lbs and is 6" taller than the new low profile 9k units. i'm tempted to switch that out but not really sure it's worth it unless i find someone wanting a trade.
That is a nice looking camper with lots of amenities. Would love an update after you've camped it it for a while. Thanks for all the pics!
Nice camper, but I'm surprised they are that heavy!
I was too. I'll weigh again once I get a bunch of the unnecessaries off of it. Our payload is 4200lbs and it handled great on and off road. Much better than expected given the weight.
locrwln said:
Any updates? Still liking the camper?
Jack
Still loving it. We had it out a fair amount during the winter and it did great down to about 0* with a 30mph wind. Winds aren't really noticeable and there's no flapping whatsoever of the soft wall. We were able to easily keep it about 65 degrees throughout the night. I put up reflectix beside the sleeping areas and it takes away the chill completely. The floor stays incredibly warm since the furnace has a return vent from the basement. I'm just trying to find the best way to store my skis, getting up the yakima box on the roof is too much of a pain. Debating mounting something on the back ladder or removing the mattress from the little pull out bunk to see if they'll fit in there.
Only bad thing I've found is that they plumbed the bathroom sink to the black tank (but luckily not the shower). I haven't talked to them about fixing it because I hope to put a composting toilet in and I'll just fix the issue when I do that.
Nice. That cabinet above the dinette may prove to be lethal.
Airbags,upgraded shocks and a swaybar should make it much more drivable
Hah I was worried about that but I'm 6'2" and haven't racked my head just yet.
I'm impressed with the handling as is. We had airbags from our last hard side camper but I ended up deflating them to 8lbs and just using the upper stable loads. I've been very happy with it.
