OregonOzzy
My Hawk couch project went in a different direction... looking to recoup what I paid for these brackets (they come with the back and bottom cushions). This was out of some RV so the cushions are quite big and may not work. I was only planning to use the brackets anyway but you are welcome to the whole thing. It even has legs to make the back in the bed position more stable. In the current config made into a bed, the dimensions are: 52"x44". The bottom cushion on its own is: 52"x28" and the back cushion is: 52"x14". The legs are 17" tall.
The dimensions of just the metal brackets when extended (bed position), tip to tip: 32.25"
In the seated position, the metal brackets end points are at: 21".
The seat bracket is: 15.75"
The back bracket is: 6.75"
Let me know if you need any specific dim or picture.
Due to size/weight, local pick up only (Beaverton, OR). Looking for $75 for the whole thing. Thanks.
http://www.wanderthewest.com/forum/gallery/album/1350-couch-brackets/
