Sail switch model number
Adventurebound
Aug 25, 2017
110
Las Vegas
Hello all. Need help locating the correct sail switch. Cross referenced my furnace (2017) build on the Dometic site and the model number does not correlate to the correct furnace? Model number AFSAD12111. I ordered the sail switch for that model and the flapper Is all wrong. In fact the diagram on the Dometic site shows the blower mounted vertical where mine is horizontal. Anyways does anyone know what part number this is? The black one is the one I need, white one is the part number cross-referenced from the model number off the furnace.
Switch I took out of furnace.
Take a look at this page. It appears to show there are two different sail switches for the AFSAD12111. One for serial numbers lower than 72498929 and one for higher serial numbers.
PDX RV TuneUp kit page for AFSAD12111
Also- when you click on the flat-blade model, it appears you may have to decide between a 33081 and 33082 based on the bracket.
Also- PDX RV AFSAD12111 manuals page
This right here is why I'm on this forum. Invaluable info Old Crow. Thanks for finding this. I now have two of the correct switches on order.
