Propane sensor
campito
Jun 7, 2020
72
Bishop
I replaced my propane sensor, original since 2012. When I was installing I noticed these two green wires in the cabinet not connected to anything and I have no idea what they are. I assume part of a standard wiring and my configuration did not use them
Power for refer fan.
The other wire end is near the upper vent behind the fridge. You probably have a 3 switch panel with one missing for Refer Fan.
Mine works now. I got a switch from FWC, installed it and added a small 12 volt computer fan that I tie-wrapped to top louver to keep cooler air in space behind fridge. Makes fridge happy on hot days.
