Diesel Heater in Your Camper?
Update on my portable diesel heater....
1. My suitcase-style portable heater sits outside and pushes the warmed air into my van through a 10-foot duct hose. That means about six feet of the hot-air duct is exposed to cold outside air before it enters the van. I recently bought Eberspacher MaxiTherm insulation blankets (off Ebay) to insulate that section. I went with snap-on blankets rather than slide-on tubular blankets as I figured the snap-on style would be easier to dry out when they get wet. They also fold down small enough to store in the heater case between uses. On my test on a 40*F day, they made a 20-degree difference in the temperature of the air at the outlet (in the van).
2. I noticed the brochure for the heater now says it operates up to 13,700 feet elevation. I called the distributor to ask if mine was good for that as the ad had said 8200 feet. The answer was that yes, all of them in the last five years are the auto-compensating HA (High Altitude) ones. He did tell me to remember that performance degrades at higher elevations. I took that to mean the elevation specs have to do with heater output. In other words it will put out the full btu rating up to 8200 feet and will run at higher elevations but heat output will be reduced. He also reminded me to always use kerosene at elevation.
3. I've not used the heater in the last year. We took it along on our western Canada trip but never got into cold weather by our return in early October. We had a few overnights into the 30s (F) but the warm days kept the van warm enough that we didn't need the heater by bedtime. I do run the heater for a half-hour every two months for maintenance and it always starts easily.
I see that the new Scout popup camper has an external diesel heater mounted on the passenger side rear wall in what appears to be an aluminum case. Any insights as to the manufacturer? They appear to use Autoterm diesel heaters in their hard side camper. Autoterm has a portable diesel heater model in what appears to be a plastic case but the Scout version isn’t this model, at least in the form factor that appears on the website.
I wonder if this can be an option on ATCs or FWCs.
I see in this Scout video about the diesel heater that the comments include a reply to "TheJensss" where Scout says the heater is an Autoterm one. Also, the controller appears to be Autoterm PU-28/Comfort Touch control panel.
The heater in the video is in a hard-sided Scout camper. I suppose it's possible they'd use a different diesel heater in the new pop-up model. I'd think they'd prefer to use the same brand to keep supply chain and dealer-training issues simpler but who knows. You may want to keep an eye out for that control panel as we see more photos and videos about the new pop-up model.
The heater itself is an Autoterm but the aluminum case it's mounted in is a Zarges case. Scout chose to use this case while the distributor of the Planar/Autoterm portables chose to put the heater in a Kanuq-brand case (I think this is the plastic one you refer to). The Kanuq case with its external fuel tank, vertical exhaust pipe and multiple air inlets wouldn't have been a good choice for this application.
Thanks Old Crow, the Scout video is very informative. I like how they route the combustion air and exhaust outside the camper. I also like how they vent the warm air directly into the camper without a warm air vent exposed to the exterior. Ditto for the enclosed fuel tank.
Are there any opinions about whether this is an option for ATCs and FWCs?
<snip>
In my opinion a diesel heater is a viable option for a truck camper as they can safely produce a dry heat, they operate economically and (if optioned for it) they can operate at elevation. Downsides include (1) installation can be tricky (in a slide-in camper) (2) you have to deal with another fuel type (3) you can't (typically) take it to a dealer to get it fixed (4) it blows cold air for a while as it fires up (5) it should be run every two months or so year round as a preventive-maintenance practice (6) the fuel pump can make an obnoxiously loud ticking sound if not mounted and vibration-isolated adequately (7) diesel fuel can gel in cold temperatures
Here is my diesel heater install. Been using it 3 years now. Jan 2. 2024 thru Feb 16 in Ouray, CO. Ice climbing. Back to CO in May for 3 weeks spring alpine season this year. It is cold up there that time of year. No problems with heater. Headed back in Jan 2025. Still same cheap heater in home built camper 3 years now.
I think when/if my OEM heater fails, I will go with the diesel. Since my truck is a gaser, it would require carrying a third fuel source. On my Cutwater cb30 I run a Webasto heater that is fed from the 180 gallon tank that powers the Volvo Penta D6 power plant. I must say that it is the most even, comfortable and consistent heat I have ever experienced.
If I were to consider one I'd probably go with the portable unit. So far my twenty year old Suburban furnace shows no signs of giving it up.
We have a 5K diesel heater mid range price point (600$)
We love it use it all winter mounted inside our flatbed hawk. Only regret is placement for easy access for maintenance haven’t done much other than change flow plugs. Will be moving the heater to easier spot for maintenance this fall. Fuel consumption is minimal, I do a burn off before shutting down turn it up to max for a bit…keep carbon from build up. We generally run the heater on low keeps us very comfortable.
Having experienced force air propane and diesel wouldn’t go back?
Hoopy, can I ask how you know when it’s time to change the glow plug? Are you doing that when something’s wrong or after a certain number of hours or ???
What are the "mid-range" heaters? I feel like I've only seen the cheap $100 ones and then the $1,000+ ones (Espar, Planar, etc).
Is there something in between?
Are folks using 2kw or 5kw heaters in their pop-ups? Does the 5kw pull more power at startup? Planning on running a 5kw off of a Yeti 1000x.
This video series is very well done.
Currently have one in my Alaskan, had the same one in a tall insulated canopy before that. First time I was in my buddy's Troopy with one, I knew I had to have my own. I haven't found anything that works better. His was a Webasto, mine is a cheapo. buy two if you are worried about reliability.
Those who say they are loud, are confused or parking on top of each other. Loudest thing is the pump, and if you make sure to not solid mount it, it can be quiet as well. They sound about like someone blowing through a straw.
Favorite mod for mine was getting this simple controller. A knob and two buttons, so much easier!
full
I could have installed the unit under the seat, but was easier to put it in the service box on the other side, not very fun to install things down in a hole. Heat on the left, intake air on the right. Did without the recirculation at first and It worked, just isn't as efficient when it has to heat up the cold air from a non-insulated steel box. Still have room to store my pillows down there as well.
full
