2 pin 12 volt connector replacement
Oryguntroutbum
Dec 15, 2012
396
Central Oregon
My 2 pin 12 volt plug on my 64 is rotted out and I need to replace it. Any idea if these will work as a replacement?
http://www.ebay.com/itm/Chrome-Plated-Brass-Marine-Power-Deck-Connector-for-Boats-/130858678663?pt=Boat_Parts_Accessories_Gear&hash=item1e77c8f987&vxp=mtr
I don't see why not if you aren't running anything more then a couple of LED lights. It is only rated at 3 amps which is only 36 watts @ 12 volts.
Get two of these and you'll never have to worry about amp ratings. You can solder the wire into these terminals (propane torch and rosin solder) so no special chimp tools needed.
(Anderson powerpole SB50 with 10ga terminals) http://www.ebay.com/itm/Anderson-SB50-Connector-Kit-Red-10-12-Awg-6331G2-/370753154988?pt=LH_DefaultDomain_0&hash=item56529c2fac
