pawleyk
Updates-
Had the battery tested at Batteries Plus. Guy threw the load tester on it and said it was more than good...
I also tried plugging the camper into 110 and using the converter. I had the same results. When the converter wasn't hooked to the battery, it read about 13v. After connecting to the battery, it dropped to just over 12.
I'm really not sure what it could be.. maybe something with the ground inside the camper? I'll try bypassing all the FWC wiring tomorrow and see what I can get with my own grounds.
I'll also probably pull the 120lb battery and see if I get the same result outside the camper, from jumpers maybe.
