jlandreneau
- Joined
- Sep 16, 2022
- Messages
- 1
Price: $40,000.00
Contact: Text or call at 404-834-5727
We are selling our Four Wheel Camper Grandby Flatbed purchased new in November of 2019 and deliver/installed June of 2020. We lived full time in the camper from fall 2020 to fall of 2021. The camper has been unused since fall of 2022. The camper is in great conditions. The exterior has some pinstriping and dents from many off-road miles, but nothing atypical.
The systems of the camper have been significantly upgraded from the stock configurations. The electrical system is powered by 300Ah of lithium batteries with a 2KW inverter/charger to provide AC/DC power anywhere and anytime. Off grid recharging is handled with 480 watts of solar on the roof and a 30 amp battery to battery charger. The plumbing drainage system has been revised to be a single ¾” stainless steel gray water drainpipe through the floor of the camper. This drain connection is designed for a vehicle chassis mounted gray water tank.
The kitchen has been upgraded with a 1800W induction cooktop that stores below the counter for travel and a stainless steel kitchen faucet with spray hose. The stock drinking water capacity has been significantly increased with an additional 35.5 gallons in a flexible tank in the passenger dinette storage area. The additional tank is piped into the factory fill and outlet hose, so no additional filling or tank switching is required. The total water capacity is now 55.5 gallons. The factory propane system has been completely removed in favor of an all-electric camper. Heat is provided via a diesel air heater. A water heater is not included but can be added as either an electric or fuel option. There is space in the stock location for a water heater to be added. An exterior access panel has been added with the various inlet and outlet fitting for the diesel air heater and a water heater.
The interior cabinets have been modified and upgraded to improve storage and useability. Improvements include a shoe rack along the rear wall of the dinette, a bookshelf with top storage above the battery compartment, and a spice rack above the kitchen countertop. We have also added several shelves in the kitchen and entry cabinets. The dinette shower has been removed to increase floor area but can be easily reinstalled if desired. We are happy to reinstall prior to purchase. All water lines for the indoor and outdoor shower remain as installed by FWC. Finally, the dinette storage areas have been subdivided to improve gear management. We use the passenger side storage as a pantry and the driver side as gear locker.
See below for a list of factory selected options and upgrades made to the camper.
[SIZE=16pt]SPECIFICATIONS & UPGRADES[/SIZE]
Battery Capacity – 300Ah
Inverter Size – 2000W
Water Capacity – 55.5 Gallons
Solar Array Size – 480W
Heater Capacity – 7,000 BTU/h
Factory Options
130L Isotherm Refrigerator
Powered Roof Vent
Extra Roof Vent at Bed
Yakima Tracks on Roof
Side Wall Steps for Roof Access
Exterior LED Lighting
Thermal Pack Interior Liner
Hot Water, Inside & Out (Hot Water Removed)
King Bed Slide-Out (Removed)
Removable Carpet Kit
Water Tank Cabinet Cushion
Silver Spur Interior & Exterior
Artistry Indigo Fabric
Exterior
Custom 80/20 Aluminum rear rack for traction boards and other gear
Interior
Custom kitchen spice rack and counter top storage
Rear wall shoe storage & additional table arm support
Bookshelf with top storage for a “night stand” above battery cabinet
Jacket hooks at dinette for jacket storage and throughout camper
Corner shelves at rear wall
Entry storage pockets
Fold up hooks to right of entry above entry cabinet
Magnetic panels on front and rear popup support panels
Subdividers in dinette storage
Shelf in entry cabinet
Shelves in kitchen cabinets
Towel bar at kitchen cabinet
Entry cabinet mounted stainless steel wall trash can
High quality foam mattress, firm
Storage sleeves on rear of dinette backrest cushions for laptops or files
Systems
Electrical
(3) BattleBorn 100 Ah Lithium Batteries
BlueSea 400 Amps ANL Fuse Holder
Sterling Power BB1230 12V Battery to Battery Charger 30 Amps
BlueSea Circuit Breakers & Disconnect Switches
BlueSea 300 Amps ANL Fuse Holder
Victron Color Control GX Monitor
Victron BMV-712 Battery Monitor with Temperature Sensor
Victron BlueSolar MPPT SmartSolar Charge Controller 100|50
Victron Multiplus 12/1200/50 2KW AC Inverter/Charge
(3) Renogy 160D 160W Solar Panels
BlueSea Fast Charge 4.8A USB Charge Socket behind dinette backrest for Wifi Hotspot Charging
MobileMark 7-in-1 Cellular, WiFI, & GPS Antennas mounted on roof
Plumbing
Imtra Nauta 35.5 Gallon Flexible Water Tank
BlueSea M2 OLED Tanks Monitor
¾” Stainless Steel Gray Water Drain Connection
Stainless Steel Kitchen Sink Faucet with Pull Out Sprayer
Mechanical
Planar 2D Diesel Air Heater
EXTRAS
(4) Rieco Titan Manual Camper Jacks – Zinc Plated
All manuals for installed equipment
MAINTENANCE NOTES
Factory Options
Powered Roof Vent
Exterior
Interior
Systems
Electrical
Plumbing
Mechanical
EXTRAS
MAINTENANCE NOTES
- All upgrades made in a high quality and professional manner using marine grade components, fittings, and wire
- Front door interior slide handle is damaged, but functional
- Refrigerator safety latch is damaged and not functional. Refrigerator is functional and door is secure
- Freezer door is damaged and not functional
- Water tank monitor is not functional
