Greetings! Apologies I've been off the net for sometime. Work is demanding. Since my first post we've taken the camper out of her maiden voyage. I completed the insulation and used Leak Seal by Rustoleum as a temporary solution until I can patch the vinyl. It seemed to work well by keeping the elements out. The old vinyl is already very stiff and this made it stiffer. The secondary effect was that it made it difficult for the front to collapse and clamp properly as the material bunched up in the panel. As I mentioned this temporary until I patch the vinyl and eventually replace the whole thing this summer. Also, I will be replacing the panel with the electrical conduit (MTF).
We bought a Mr Buddy Heater and it gave us 5 1/2 hrs of continual heat. Running it all night long was necessary as we had our dogs with us. As you can imagine 4 bodies and a propane heat source generated a TON of moisture. Humidity was 76% at the highest. The ambient temp outside was in the teens and it stayed a nice 54 inside. The heater can be found at Walmart for 79 bucks. Far cheaper then anywhere isles I looked. Also, you can buy a 2 pack of 1lb propane bottles for 6 dollars. The plan is to get a 10lb propane tank and use that for the heat and cooktop. Overall, we were pretty warm and snug.
I extended the bed by 6 in with a wider piece of sanded plywood and replaced the old piano hinge with a new one. I ditched the old smelly foam pads and bought two 2" thermOrest pads from Sierra Trading Post at 35 bucks a piece. Made in America. Pretty good deal. I went with these bc I can deflate them and keep the double wide sleeping bag on top so I can collapse the camper with only having to remove the pillows. It's nice to keep the bed made and makes it more homie. The sleeping bag is rated to 0 F. We bought this in Alaska and it works wonders for car camping. The bag is thick so even without pads it is very plush and comfortable. I also went with the thermOrest pads so we can use them for tent camping with the car. We have other lightweight ones for backpacking... anyways I also replaced the old table top with a piece of the plywood that was cut for the bed. I haven't had time to stain or paint these. The subtle change made it look a lot nicer. I will install some brackets so the table top can be used to create second sleep area for guests in the future.
Probably the most time consuming and labor extensive addition was the camper dolly. I don't have a garage so that complicates my renovation a bit. At the end of my driveway I have a fence with a pedestrian gate. I made it a double wide swinging gate by installing heavy duty hinges on the other side, cut loose some posts and added a wheel pedestal. It came out really clean. Behind the gate I cleared our firewood and leveled the ground so that I can back the camper into the yard where it can be secured. I am going to make this a little "camper" port by putting up some corrugated steel walls around it and a sun shade sail over it (amazon cheap). I'll finish it with some solar powered lighting. It'll look pretty clean when compete.
Back to the dolly, now that you can picture the circumstance I went with a trailer. I saw on another post one user suggested going with one of the Harbor Freight trailers. I went with the 1200 lb 48x96 in version. I got a coupon so under 300 bucks that was a deal. Of course, anything that sounds too good is. Putting it together was a pain in the ass. 90+ bolts. Worse then IKEA. Luckily I have a pretty good buddy who offered assistance. Over a 6 pack of Odell 90 Schilling we did it in 6 hrs +. The trailer was still not high enough to lower the camper all the way down. I built a platform using 2x4 double stacked with a 3/4 plywood on top. I painted the wood with porch latex gray to help weather proof it as it will be outside. It came out great. My favorite part about the platform is I sunk the bolt heads securing the 2x4s so the plywood sits flush. The plywood board is secured with a number of coated woods screws. After that, I was finally able to lower the camper with my 4x reico jacks. I bought four bc my drive way is tight and I don't want to risk the camper crushing me between the house and driveway. Pricey but safe. I paid less for the camper haha.
I'm going to move on to the electrical next so I can put the Luan walls up. I am going to install a 6 gang switch panel with 12v port, voltmeter, and USB port. This will be an exercise in futility as I am electrically challenged. Which is ironic bc my father is a master electrician and general contractor. Thank goodness for the interwebs.
