Airbag spacer?
randygirl
Sep 9, 2010
170
SW Florida
Ok, went to insatll the Firestone Ride Rites and they didn't fit right....
Called Firestone and they said I needed a spacer (2 inch) cause of the TRD off road package.
After an extensive search on this forum, I never saw anyone mention it??
Am I crazy or do some of yoou have the spacer also?
Thanks
Randy
My 06 Tundra TRD came with 18" wheels. When I installed ride rites, there was only 1/4 inch clearance, so I went with a slightly narrower tire (265/65) when I got my E load BFG's. Now I have 1/2" clear. Hope that helps.
I think I worded that wrong...
The upper bracket only had the top 2 holes reaching the frame. Firestone said I needed some sort of "spacer" to lift the airbag so all 4 holes on the upper mounting bracket reach the frame...
The photos and directions are slightly confusing...
Especially when all did not fit right. They did not put 2 of the bolts needed in so I really was confused
And I thought working on the VW was confusing!!!
Here's a photo of the Ride-Rite installed on 06 Tundra.
Hope that helps!
