kkug
Anyone add a extra grab handle across the door from the orginal one ? I like to have a bit more grip exiting the camper . I got a orginial one and my first attempt was not successful .
+1 on bothlonghorn1 said:Never used the grab handle. I use the sink or the door frame. We all have a way in and out, just mine. jd
I added the same interior handle and love it for closing the door. Seems like they should add it as an option.Zirdu said:My wife didn't like the metal grab handle supplied with my 2016 Grandby. She found a much bigger, padded plastic grab handle, which I installed. You can see the screws where the old handle was installed. I just screwed these back in with a little silicon to plug the holes. I attached the new handle with a hard rubber gasket and silicon, and two screws for each end. It seems to be very solid, and has held for a year so far. It does make for an easier and more secure grab bar. We both usually go out the door backwards. At first I was not in favor of this change, but after I did it, I really like it better than the original handle.
She also found a lightweight grab bar for the inside of the screen door. This helps for balance in entering and exiting. It is also very helpful in closing the screen when the main door is open.
I've been looking at the 3-step Easy Hitch Step and curious about one thing. I have a Swift on a short bed frontier and the camper extends out 12 inches from the back of the truck...….how far out from the rear of the bed does the top step on the easy hitch extend out? Those things are not cheap and I don't want to spend the money only to find it doesn't work.Andy Douglass said:I use the stock grab bar when entering more than exiting. We got the 3-step Easy Hitch Step, so half the time when I exit I just walk down the steps forward like any normal steps. If I am carrying anything out, I tend to walk out backwards for some reason. I can't recommend the steps enough: solid, easy to deploy/fold up, and the steps are always in the same place regardless of the terrain since they are mounted to the hitch receiver and don't even touch the ground. No need to stow a rickety step ladder that may or may not have mud all over it, and the steps are a huge increase in safely entering/exiting. If weight/money are not a consideration, I think they are the best upgrade to the entry that can be made.
