Zirdu, saw your pics on the grab handle and screen door cross bar. I got both right away, but having issues mounting with both. The big grab bar mounting spots above and below stock bar have nothing solid to anchor into except thin wall, and I was wondering if you drilled through into interior and used thru bolts and nut and big washer inside. Sheet metal screws will do god now but god repeated use long term, I am wondering if it will hold up. Also, I had a screen door bar in my older Grandby and was very glad I installed it few years back. Now I gif a newer model with the wider door and door seal, I found out that mounting the bar to clear the door lip is a problem. In your pic, it shows that your mounting is on the inside edge of the screen door frame, maybe drilled in af an angle?
I may have to fashion a Z mount so the bar mounts can clear the door frame. Anyone else had the same problems and have solutions?
