Anyone With "Drymesh" Experience?
Brad's Dad
Jul 7, 2010
55
Northern Wisconsin
Has anyone invested in this system and how has it worked out in cool humid environments? I am leaving for Denali Park, AK May 1 and plan to camp along the way and will be using it there thru September.
[SIZE=10pt]http://www.drymesh.net/[/SIZE]
I have factory 2" foam and am looking for something that will allow me to:
1) reduce under mattress condensation. I have a factory furnace or electric space heater and always vent the camper a little overnight.
2) allow me to keep the system in place while traveling/camping for extended periods without needing to remove and store elsewhere.
3) works using one piece the size of one of the 2" factory foam mattresses. I seldom pull the bed out when sleeping and am hoping the 1/2" of extra height under the forward mattress (if I do pull it out) will be tolerable for occasional use.
4) will allow me to close the roof without clearance issues: 4 1/2" total thickness or 1/2" more than just the factory mattresses?
Thanks for anyone's experiences here in advance!!
Fred
There are numerous threads on mattress condensation and cab-over insulation.
The Drymesh works by allowing air circulation keeping the mattress separated from absorbing what condensation does form. In dry climates it requires almost no maintenance. In extreme humid cold weather, each morning, I double back half the mattress along with the Drymesh and towel dry underneath. The Drymesh keeps the mattress separated from the cold surface where the bulk of the condensation forms in these conditions. I leave the mattress folded over while making coffee. In moderate cold temperatures with high humidity, condensation forms. It can't be completely stopped, it must be managed. It can however, be effectively managed. There is a whole bunch of previous thread information on the subject. In severe conditions, I also put som foam under the Drymesh. That product is covered in a previous thread too. Other product probably work too, but Drymesh is inexpensive, it can be flipped up with the mattress to dry and you can also toss it in a washing machine.
Hope this helps.
Fellas, Great Topic. I'll Be Watching It And Reading Up On Some Of The Threads That Were Suggested. I Haven't Yet Had Troubles (That I Know Of) But Will Start Keeping A Better Eye On It.
KILROY
Thanks Kilroy, you are right there is no Drymesh thread, so I am going to expand on this for others and attempt to put it to "bed",.. Pun intended. I spend a lot of time in PNW humid cold conditions and have experimented greatly. I believe in this product.
When I spoke of folding the mattress back above, I should have further explained that I fold the upper torso portion back. That is where the majority of the body heat is and so where most of the condensation forms. I also reach under the folded portion to towel under within easy reach. This sounds like a lot to do but it really only takes a few seconds. The good thing about Drymesh is that it can be easily flipped back with the mattress.
If your mattress is allowed to contact the cold surface without a Drymesh type product, it will absorb the moisture as it forms. Depending on your climate conditions, it may be absorbing the moisture and you do not even realize it. If that is the case, if used for a LONG DURATION of time the bed will accumulate the moisture and begin to feel clammy and you just feel like you can't get warm. It's really an ugly feeling.
If I am going to be in one place, after flipping the mattress back down, I leave the bed turned down. This allows body humidity to also escape from the bedding during the day.
A half inch layer of foam R-Tech Insulfoam with the reflective side down under the Drymesh also helps by cutting down the cold transfer against the body heat. This product is very inexpensive, comes in different thicknesses, available at all big box home builder supply type places. It is easy to cut and I tape the edges with foil tape to enhance the durability. Here is a link.
http://www.insulfoam.com/images/stories/docs/6012_RT_Insulation.pdf
As for thickness, you need to be the judge of that for you model year FWC. FWC does a good job of building to maintain a low profile for most client climate conditions, That's why we buy them. Though my system is difficult to explain, it is not difficult or time consuming to do. It is also only needed for a long duration, otherwise just air it out when you get home. Nor is there any need to air stuff in dry climes. Other measures to reduce condensation help I,e., less heat, vent, and methods of preparing food.
Did I say both of these products are inexpensive? Both of these products are very inexpensive.
Fred
I believe the original factory foam was 4" and has been reduced to a 3" foam of better quality. The dry mesh appears to be woven mesh, so how does it get 1/2" in thickness. The photos don't show anything very thick. Just curious.
Wowsa... I estimate that it will cost about $140 for the Hypervent. Yes indeed, they all seem to be quite expensive.
Kilroy, I would guess that both the Drymesh and InsulFoam can be purchased for something slightly north of $100 bucks. I don't remember the exact number. I toss the Insulfoam when in warm climes and throw in some new when headed to higher latitudes. It is relatively inexpensive. Carlin would say, "What is... relative and to whom?" Always liked that guy! Drymesh does seem to be a bit pricey. I racked my brain to think of a similar less costly product that might do the trick, but couldn't come up with anything that would fold back and be washable. Perhaps someone here may know of something?
Longhorn1: here is a link that better defines the thickness.
http://www.drymesh.net/orderdrymesh.php
One more thing,.. If anyone is purchasing a mattress other than factory, it is best to size it with a couple of inches of breathing space all the way around so air can circulate around, under and through the Drymesh.
Great information. I'm adding some of this (one brand or another) to my wish list for 2014.
Great idea, I'll be watching for some results. My guess would be that it would soak up some moisture, but not a ton. At least you would be able to lift the mattress after a trip and pull the lattice out. It would result in less absorption in the foam mattress material (and cover) and less drying time overall. Let me know if my hypothesis is correct please.
The worst you'll get it a nice smelling camper.
This page http://www.drymesh.net/contactus.php
1) tried the "Contact Us" form... no indication it actually does anything
2) tried "Call Us" at 203 501 3261... it said, "This person has not yet setup a mailbox. Goodbye."
3) tried email to sales@drymesh.net ...
Delivery to the following recipient failed permanently:
sales@drymesh.net
Technical details of permanent failure:
Google tried to deliver your message, but it was rejected by the server for the recipient domain drymesh.net by drymesh.net. [50.87.75.142].
The error that the other server returned was:
550 User is prohibited from forwarding mail
This page http://www.drymesh.net/termsconditions.php
" Alternatively, you may contact us by telephone on 203 917 1972"... always busy
This page https://www.facebook.com/pages/Meridian-Alliance-LLC/107651329265827
is about 99.99% blank.
Mike
Mike
My exact experience also!
Fred
When I called the number, someone answered and it was a personal cell phone. The poor guys is getting all types of calls. He tried to contact them to pull is number and couldn't get anyone. I think they went out of business.
http://whois.domaintools.com/drymesh.net
Registrant Name: Peter Quinn
Registrant Organization: Meridian Alliance LLC
Registrant Street: hedge house hangersley
Registrant City: Ringwood
Registrant State/Province: Hants
Registrant Postal Code: BH24 3JW
Registrant Country: GB
Registrant Phone: +44.1425480605
Registrant Phone Ext:
Registrant Fax:
Registrant Fax Ext:
Registrant Email:
Maybe I'll get a response from peter.
Mike
I'm assuming that since under mattress condensation is an issue, FWC does not have the block foam insulation built into the cabover portion? If not, I'm surprised that they do not do this since the rest of the hard walls have it.
