Arctic pack .Washable?
Depends on what you mean by "wash". I wouldnt toss it in the washing machine. There shouldn't be any problem scrubbing with a sponge and mild detergent. I'd 303 it after I was done.
Stan posted up what it is made out of here http://www.wanderthe...page__hl__artic pac__fromsearch__1
Pasted below is some details and toward the bottom is the care, I enlarged and bolded the text.
here are some basic pictures ...
http://www.fourwheel.../artic_pack.htm
the option cost if you order the arctic package on a new camper is $ 475.00.
details on the material listed below ...
The Arctic Pack - Evolution III Fabric by Kimberly Clark
A 100% polypropylene nonwoven fabric (olefin fiber)
History
Italy began producing olefin fibers in 1957. The United States began producing olefin in 1960. Depending upon its chemical structure, olefin may be called polyethylene or polypropylene. It is also referred to as P2 for short.
Production
Olefin is produced in much the same way as polyester and nylon. The chemicals used to make olefin are melted and fed through a spinneret head (similar to a large showerhead) where it then forms a long fiber. The fiber then solidifies by some cooling process. Variations and additives used during the manufacturing process of fibers can alter the characteristics and end uses of the fibers tremendously.
Characteristics:
Aesthetics – The luster and texture of olefin can be modified to fit the end use. It is usually manufactured with a smooth texture and medium luster.
Good abrasion resistance
Dries quickly and carries moisture away from the skin
Resistant to degradation by chemicals, perspiration, mildew and weather
Stain resistant – Olefin is not affected by most chemicals; consequently, it is not easily soiled or stained.
Excellent strength – The strength of olefin can be modified to fit the end use.
Colorfast – Olefin holds its bright colors well and is resistant to fading. Carpets made of olefin have been proven to have fade resistant properties of almost three times the industry standard.
Lightweight – The low density of olefin makes it possible to manufacture lightweight products that are highly durable. Olefin is the lightest textile fiber.
Environmentally Friendly – The production of olefins leave very little waste byproducts or residue. Olefin is easier to recycle than most other fibers. Olefin, in its basic form, is made into packaging materials. These materials are easily melted and reused. Tyvek ProtectiveWear by DuPont is an olefin material that is 25% recycled. Because olefin is usually solution dyed, the environmental problems related to dye chemicals do not exist. Oelfin is actually beneficial to the environment through its use in erosion control fabrics.
Very low moisture absorbency – Waterborne stains are not a problem, due to olefin’s nonabsorbency.
Very low static electricity problems – This characteristic makes it an excellent choice for office furniture coverings, carpets and automobile interiors.
Good thermal retention - Lining made of olefin helps keep you warm by trapping the air in the space between the layers. On the other hand, olefin also keeps you cool in the summer.
Excellent Resiliency – Olefin recovers very quickly from wrinkling.
Excellent Shape Retention – The attractive appearance of olefin lasts for years.
Care
Eventhough olefin has a low melting point. This factor limits its use in apparel fabrics. Fabrics made of olefin should be spot cleaned or washed in warm or cold water. Olefin fabrics should be air dried or dried at low temperatures. If ironing is needed, a low temperature setting should be chosen.
ARTICLE # 2
Olefin Fiber
(Polypropylene) (Polyethylene)
Olefin Staple Fiber
Olefin Filament Fiber
Olefin Carpet BCF Filament Fiber
Olefin Film Fiber
Polyethylene Fiber - (Spectra) more
First U.S. Commercial Olefin Fiber Production: 1958, olefin monofilaments for various specialized uses; 1961, Hercules Incorporated, textile grade multifilament polypropylene
Current U.S. Olefin Fiber Producers: American Fibers and Yarns Company; American Synthetic Fiber, LLC; Color-Fi; FiberVisions; Foss Manufacturing Co., LLC ; Drake Extrusion; Filament Fiber Technology, Inc.; TenCate Geosynthetics; Universal Fiber Systems LLC
Federal Trade Commission Definition for Olefin Fiber: A manufactured fiber in which the fiberforming substance is any long-chain synthetic polymer composed of at least 85% by weight of ethylene, propylene, or other olefin units, except amorphous (non-crystalline) polyolefins qualifying under category (1) of Paragraph (I) of Rule 7. (Complete FTC Fiber Rules here.)
Basic Principles of Olefin Fiber Production — Olefin fibers (polypropylene and polyethylene) are products of the polymerization of propylene and ethylene gases. For the products to be of use as fibers, polymerization must be carried out under controlled conditions with special catalysts that give chains with few branches. Olefin fibers are characterized by their resistance to moisture and chemicals. Of the two, polypropylene is the more favored for general textile applications because of its higher melting point; and the use of polypropylene has progressed rapidly since its introduction. The fibers resist dyeing, so colored olefin fibers are produced by adding dye directly to the polymer prior to or during melt spinning. A range of characteristics can be imparted to olefin fibers with additives, variations in the polymer, and by use of different process conditions.
Olefin Fiber Characteristics
o Able to give good bulk and cover
o Abrasion resistant
o Colorfast
o Quick drying
o Low static
o Resistant to deterioration from chemicals, mildew, perspiration, rot and weather
o Thermally bondable
o Stain and soil resistant
o Strong
o Sunlight resistant
o Dry hand; wicks body moisture from the skin
o Very comfortable
o Very lightweight (olefin fibers have the lowest specific gravity of all fibers)
Some Major Olefin Fiber Uses
• Apparel: Activewear and sportswear; socks; thermal underwear; lining fabrics
• Automotive: Interior fabrics used in or on kick panel, package shelf, seat construction, truck liners, load decks, etc.
• Home Furnishings: Indoor and outdoor carpets; carpet backing; upholstery and wall coverings; furniture and bedding construction fabrics
• Industrial: Carpets; disposable, durable nonwoven fabrics; ropes; filter fabrics; bagging; geotextiles
General Olefin Fiber Care Tips
o Most stains on fabric can be readily removed by spotting with lukewarm water and detergent.
o Bleaches can be used if needed.
o If fabric is laundered, it should be line dried or tumble dried with gentle heat or no heat. Olefin dries very rapidly.
o Do not iron. (For specific instructions, refer to garment's sewn-in care label.)
