Jamesiam
I removed panel on rear of 1996 Ranger II FWC , then removed plastic cover that surrounds fan unit and replaced fan switch. I am having trouble locating Limit switch?
By following a spec sheet for this Atwood unit there should be 2 wires that flow from sail switch , 1 to Limit switch, one off to another stop. 1 should be blue the other either blue or white. I follow one wire that seems to go into camper, the other that goes to what seems like a 5 prong nickel sized unit attached in viewable area next to fan unit. not comparable to my dime sized 2 prong unit that I purchased as my limit switch.
My question is do I have to remove furnace to get to limit switch? Or maybe did I recieve the wrong limit switch from RV store, and am actually staring at limit switch?
