Avatar image files are limited to 140x100 maximum dimensions and 10k in file size. If you upload a file larger in dimensions than 140x100 then it will be scaled to the correct dimensions but you still can't exceed the 10k file size limit.
The dimension limits of 140 wide and 100 tall mean that you will be able to have a much larger effective image if you use a wide photo rather than a tall one.
