Glenn
^^^^ Jon R, I’m starting to buy components - what would your recommendation be for positive (+) cable size from the house battery positive post (and fuse size) out to the positive bus bar and loads), given your reply above? Wondering if the #6 is too small?Even with the CPAP machine at 2 plus amps continuously all night plus the fridge and other loads, i think your usage in a 24 hour period won’t exceed 50 amp hours.
(As we discussed earlier for the dc to dc charger itself it will be the #6 wire and a 50A fuse, (thank you for that!) but I wasn’t sure on a fuse size for just the house battery even though it has built in 200A BMS)
I saw a post that said fuse size should be max amp load plus 25% but I know that my estimated 50A hours consumption in a 24 hour period won’t be all at the same time.
I didn’t mention, I’ll be using an ANL style fuse block to accommodate the cable and lug terminals.
Here’s a link to the battery I bought. I decided on it by pouring over manufacture specifications and buyers reviews and ratings. I wasn’t a member of the Wander the West forum yet or I would have asked. I know you had questions about it, and honestly I’m still trying to understand all the built in features. The internet reviews (top 10 LiFePo4) seem to change all the time, I really hated breaking the bank on some of the ones that were deemed best. I guess I’ll know in time in how it functions for my purposes.
![www.eco-worthy.com](/proxy.php?image=http%3A%2F%2Fwww.eco-worthy.com%2Fcdn%2Fshop%2Ffiles%2Fecoworthy_12V_280Ah_lithium_battery_1.jpg%3Fv%3D1696987304&hash=0a0554a341747e997ac19920ebd683b7&return_error=1)
LiFePO4 12V 280Ah Lithium Iron Phosphate Battery | ECO-WORTHY
ECO-WORTHY LiFePO4 12V Lithium Iron Phosphate Battery has twice the power, half the weight, and lasts 8 times longer than a sealed lead acid battery, no maintenance, extremely safe and very low toxicity for environment. Our line of LiFePO4 offer a solution to demanding applications that require...
![www.eco-worthy.com](/proxy.php?image=https%3A%2F%2Fwww.eco-worthy.com%2Fcdn%2Fshop%2Ffiles%2Fbanner-1_efb2cb9d-f2e4-4fb6-8d12-78b7d6e16d21.jpg%3Fcrop%3Dcenter%26height%3D32%26v%3D1673514223%26width%3D32&hash=754c35c3f7c9fe6d0dbc85ee984bf4ae&return_error=1)
Thanks, Glenn
