New Fleet shell + Gen 2 Tacoma owner here. Want to add sun shade capabilities for warm weather and exposed dispersed camping. I have a number of questions and request your insight.
I can afford the cost of a new awning, but want to make a darned good decision the first time around, rather than fix it later. I also tend to over-analyze decisions like this to a fault. Sorry in advance.
1. Soft case awning vs camp tarp?
Considering BASIC, inexpensive soft case awning, such as ARB, Eezi-awn, Roam, etc:
https://www.roamadventureco.com/collections/awnings/products/rooftop-awnings
Also considering a 12x12 camp tarp and two telescoping poles as an alternative:
https://www.rei.com/product/177675/rei-co-op-trailbreak-tarp-12-x-12
I'm a middle-aged former raft guide and have a Ph.D in Tarpology. Pitching a bombproof tarp at the end of the day, with camp beer in hand, provides immense satisfaction. It also makes my girlfriend roll her eyes.
Awning PROS: easier to set up and take down, you always have it handy
Awning CONS: more expensive, heavier, need to consider various mounting options (possibly drilling holes in camper) EDIT: Pools rain
Tarp PROS: cheaper, less weight ON the camper, can set it up where you want to sit/cook rather than always located on the passenger side of the camper, can be used to SAVE/occupy your campsite if you drive your camper into town.
EDIT: Can be set up to prevent rain from pooling.
Tarp CONS: takes longer to set up, usually packed away under the seat
NOT interested in a Fiamma.
2. Soft case: 6.5' vs 8'?
IF I go the awning route, I still have not decided between 6.5' or 8'. The 6.5' fits nicely along the bed portion of the camper, without extending forward onto the sleeping portion of the camper. This is more visually appealing, IMHO. Additionally, the 6.5' awning weighs less, is easier to deploy, and is less expensive. The 8' provides more FUNCTIONAL shade.
Many people I've spoken to say they actually use their awning LESS than they anticipated. Leaning 6.5' just to have SOME shade when needed.
3. Soft case awning attachment?
IF I go the awning route, there's a plethora of ways to attach the darned thing to the camper:
A) Flush mount
FWC brackets
C) Mule Expedition Outfitters jack bracket extensions
D) Home-made jack bracket extensions
I actually like the idea of flush-mounting an awning to the side of the camper. I was inspired by THIS guy:
https://www.wanderthewest.com/forum/topic/17688-mounting-arb-awning-on-2018-fwc-hawk-12-steps/
It seems MOST SOLID, with less potential to wiggle loose while driving over rough surfaces.
A&B drill holes THROUGH the camper. I live near the FWC Mothership, but they are IMPOSSIBLE to get ahold of to do a bracket install.
C is expensive, and has an unnecessary (for me) tensioning mechanism to roll the awning forward to access the side camper latch. This is not an issue for me since I have a newer camper, and the latch is already moved forward. I also DON'T LIKE the rounded flange where the awning pivots sticking out, nor how the awning is raised to top of (above?) roof level (my gf thinks I'm being overly picky!). Plus there's that gap between the camper and awning.
https://dasmule.com/products/mule-four-wheel-camper-arb-awning-brackets-pre_order?_pos=1&_sid=45a0d29e5&_ss=r
Mule also makes a FIXED bracket for their batwing, which I've been told by Mitch at Mule, that it will work for a 6.5' or 8' awning:
https://dasmule.com/products/mule-alu-cab-shadow-awning-four-wheel-camper-bracket-kit?_pos=8&_sid=45a0d29e5&_ss=r
Both Mule options are made from $tainless $teel, I believe.
There's currently an engineer on the FWC owners facebook group gathering interest in manufacturing jack bracket extension awning mounts (see attached photo below). These can be available in aluminum, steel or stainless. Price yet to be determined.
Thoughts?
A) Flush mount
Thoughts?
