paddlesurf.net
- Joined
- Dec 4, 2009
- Messages
- 56
Greetings,
Here's my situation: I will soon be the owner of a new Hawk flatbed - it will come with the dual 12v battery option but I did not get the solar panels or controller installed (I wanted to explore the land of 24v, mppt systems and at the time FWC did not offer that as an option).
So 2 questions:
1. I already own a 160watt Zamp portable panel with PWM controller already on it.
I'd like to use that 160watt portable - it was expensive when I bought it two years ago.
So... can I hook the rear FWC solar wiring directly to the battery bank and use this 160watt portable while also having an MPPT controller installed inside the camper where it would use the FWC factory wiring connected to a 24volt system on the roof?
There is a zamp drawing that seems to show that you can hook the portable directly to the house battery - bypassing the "house" solar controller. Can I only do this if both controllers are PWM?
I'm sure this is a bad/foolish/stupid idea - please educate me.
2. Assume I scrap the 160watt portable zamp and I still have the 200 watts at 24volts upstairs - is there any way I could get a portable panel in 24volt configuration that I could control with the house MPPT controller that is not giant?
Does anybody with a 24 volt system have a portable 24volt panel(s)?
So 2 questions:
