Bailey's 2018 Raven Shell - Build & Photos
Hi Bailey
Where did you find the adapter for PVC fittings to the water can ?
Many thanks
David Graves
DavidGraves said:
Hi Bailey
Many thanks
David Graves
Mighty Dodge Ram said:
Yes...pics of it set up with a can, please.
I purchased the PVC parts at the local Ace Hardware. Ended up drilling a hole in the can while mounted in the AT overland can holder. I don't have a parts list for the PVC components but I remember it costing around $8 total for the fittings and rubber washers.
I am just not familiar with the fittings to connect to a plastic water container like that....handy.
And how in the wold did you do it thru the can carrier hole ?
Does it leak ?
David Graves
DavidGraves said:
Does it leak ?
David Graves
The scepter water can has a large opening up top which you can fit your arm through. It's great for cleaning and gave me access to secure the PVC fitting. Rubber washers were used both inside and out as well as thread sealant. Absolutely zero leaks.
Note: Everything was installed on the truck. I didn't remove the can as the PVC fitting would NOT fit through the hole in the AT overland carrier.
Yep...I noticed that you will not be removing the can from the bracket....maybe create a fabric cover for it to avoid UV damage to your $80 water can.
Thanks Bailey !
Hey Bailey. Like the idea of the fitting on the water can. Our local Princess Auto sells that can for under $50 (cdn) so I might just have to rig one up. Thanks.
BaileyJ said:
It's a little heavy with both panels and the track system. The roof was empty up top so it came with light-duty gas struts.
If I remember correctly, juniper overland said I could upgrade to the 60lb struts without issues. It'll probably come down the road once I get tired of putting some muscle into lifting the roof. A battery upgrade will happen first
Thanks!
-Bailey
Wandering Sagebrush said:
Russ, I have full tracks, two bars and a 150 watt panel on the Bobcat. I believe Marty put 40# struts on the camper. Very doable.
Well that's good to hear, don't know why I had not thought of a change of lift assist. Thanks for the response from you both.
Russ
Thanks Bailey !
I'm not too worried about UV damage as these were built to last. If the color fades it won't bother me. Didn't have to pay $80
http://lexingtoncontainercompanysonlinestore.mybigcommerce.com/scepter-military-water-can-20l-tan/
This site has some good prices
BaileyJ said:
Very windy this morning so I didn't get the best pictures of the new setup.
Yakima Tracks and Renogy 200W Solar Kit installed at Juniper Overland. Weboost coming soon :)
Do you have any more pics of this? specifically the rear area. ive been looking at adding a second panel, but dont think my hawk has enough room on the rails in the back.
thanks
thanks
I'll snap some pics
Tonight will be my 13th night in the camper since November 23rd. Ditched the apartment towards the end of December to full-time in this cabin on wheels
Morning stroll on thimble trail in Anza-Borrego. Found a new spot for the next 3 or 4 nights :) (not pictured)
Message me if you're exploring the desert
thanks
Been a customer of TOTAL CHAOS since 2012 and recently stopped by for a visit. While I was picking up my skid plates I talked with Nicole about something cool for Overlanders and Adventure-Campers. I am full-timing out of my Raven Four Wheel Campers and am currently spending time in SoCal. Anyone who flags me down gets a FREE TC Patch. Thought this might be fun for those who spend some time in the dirt and collect patches
Note: One per location
Hint: Look for the reflective TOTAL CHAOS decal on the back door of the FWC
Current Location: Arroyo Salado Primitive Campground
Hope to have some friendly faces stop by
-Bailey
Dude....your fog lamps are on.
Envy your time in the desert...maybe a little later for us.
David Graves
