I got an email on the sale, lets see if it will cut and paste.
EDIT: had to delete some photos that are in the add to put post up.
[SIZE=26pt]
SALE STARTS AT 9PM PST ON THURSDAY 11/26/2015!![/SIZE]
Solar Cynergy 80 Watt
12 Volt Solar Panel
ONLY $75
(Regular Price: $104)
Manufacturer: Solar Cynergy
Cells: Q-Cells
Model Name: SLP80-12
Max Power: 80 W
Open Circuit Voltage (Voc): 21.0V
Short Circuit Current (Isc): 5.36A
Optimum Operating Current (Imp): 4.65A
Optimum Operating Volatage (Vmp): 17.0V
Dimensions (inches): 33.35 x 25.97 x 1.33 Weight: 15lbs
Solar Cynergy 100 Watt
12 Volt Solar Panel
ONLY $100
[SIZE=10pt](Regular Price: $125)
Manufacturer: Solar Cynergy[/SIZE]
[SIZE=10pt]Model Name: PV-SC100J12 [/SIZE]
[SIZE=10pt]Number of Cells: 36 cells in a series (4 x 9) [/SIZE]
[SIZE=10pt]Max Power: 100W [/SIZE]
[SIZE=10pt]Open Circuit Voltage (Voc): 21.0V [/SIZE]
[SIZE=10pt]Short Circuit Current (Isc): 6.30A [/SIZE]
[SIZE=10pt]Maximum Power Voltage (Vmp): 17.0V [/SIZE]
[SIZE=10pt]Maximum Power Current (Imp): 5.80A [/SIZE]
[SIZE=10pt]Weight: 17.6 pounds [/SIZE]
[SIZE=10pt]Dimensions (inches): 44.93 x 25.97 x 1.33 [/SIZE]
Includes Junction Box And MC4 Connector
Solar Cynergy 120 Watt
12 Volt Solar Panel
ONLY $120
(Regular Price: $136)
[SIZE=10pt]Model Name: PV-SC120J12
Number of Cells: 36 cells in series (4 x 9)
Max Power: 120Wp
Short Circuit Current (Isc): 7.50
Maximum Power Current (Imp): 7.00 [/SIZE]
[SIZE=10pt]Dimensions (inches): 51.44 x 25.97 x 1.33[/SIZE]
[SIZE=10pt]Weight: 22 pounds [/SIZE]
Solar Cynergy 140 Watt
12 Volt Solar Panel
ONLY $135
(Regular Price: $159)
[SIZE=10pt]Model Name: PV-SC140J12[/SIZE]
[SIZE=10pt]Number of Cells: 36 cells in series (4x9)
Max Power: 140Wp
Short Circuit Current (Isc): 8.40A
Maximum Power Current (Imp): 8.00A
Dimensions (inches): 39.47 x 38.30 x 1.40 Weight: 23.4 lbs [/SIZE]
Solar Cynergy 150 Watt
12 Volt Solar Panel
ONLY $145
(Regular Price: $165)
[SIZE=10pt]Model Name: PV-SC150J12 [/SIZE]
[SIZE=10pt]Electrical Data
Maximum Power Output: 150 Watts
Max Operating Voltage (Vmp): 18.0 Volts
Max Operating Current (Imp): 8.33 Amps
Open Circuit Voltage (Voc): 22.4 Volts
Short Circuit Current (Isc): 8.75 Amps
Module Efficiency: 14.70% [/SIZE]
Neptune 300 Watt
24 Volt Solar Panels
[SIZE=14pt]Pallet of Ten[/SIZE]
ONLY $1770 ($0.59/Watt[SIZE=11pt])[/SIZE]
(Regular Price: $2370)
Manufacturer: Neptune
Maximum Power Output: 300 Watts
Max Operating Voltage (Vmp): 36.6 Volts
Max Operating Current (Imp): 8.26 Amps
Open Circuit Voltage (Voc): 45.2 Volts
Short Circuit Current (Isc): 8.85 Amps [/SIZE]
EcoSolar 230 Watt
ONLY $1495 ($0.65/Watt)
[SIZE=11pt]
(Regular Price: $1795)[/SIZE]
[SIZE=11pt] [/SIZE]
[SIZE=11pt]
Or 158.70 Ea ($0.69/Watt)[/SIZE]
[SIZE=11pt]
(Regular Price: $189) [/SIZE]
[SIZE=11pt] [/SIZE]
Manufacturer: EcoSolar
Maximum Power Output: 230 Watts
Max Operating Voltage (Vmp): 29.8 Volts
Max Operating Current (Imp): 7.71 Amps
Open Circuit Voltage (Voc): 37.10 Volts[/SIZE]
[SIZE=10pt] Short Circuit Current (Isc): 8.21 Amps [/SIZE]
Unik 250 Watt MONO
24 Volt SolarPanels
ONLY $1550 ($0.62/Watt)
[SIZE=11pt]
(Regular Price: $1885)[/SIZE]
[SIZE=11pt]
Or 172.50 Ea ($0.69/Watt)[/SIZE]
[SIZE=11pt]
(Regular Price: $192) [/SIZE]
[SIZE=11pt] [/SIZE]
Manufacturer: Unik Solar
Model: JSMM2503
Electrical Data:
Maximum Power Output: 250 Watt
Max Operating Voltage (Vmp): 30.6 Volts
[SIZE=10pt] Max Operating Current (Imp): 8.25 Amps
Open Circuit Voltage (Voc): 37.86 Volts
Short Circuit Current (Isc): 8.80 Amps [/SIZE]
Unik 250 Watt POLY
24 Volt SolarPanels
[SIZE=11pt]
[SIZE=11pt]
[SIZE=11pt]
[SIZE=11pt] [/SIZE]
Manufacturer: Unik
SolarModel: JSMP2504A
[SIZE=10pt] Electrical Data
Maximum Power Output: 250 Watts [/SIZE]
[SIZE=10pt] Max Operating Voltage (Vmp): 30.75 Volts
Max Operating Current (Imp): 8.19 Amps
Open Circuit Voltage (Voc): 38.2 Volts
Short Circuit Current (Isc): 8.65 Amps [/SIZE]
Pallet of 25
Stion Solar Amorphous Thin Film
125 Watt 48 Volt Solar Panels
Stion STL-125
[SIZE=16pt]ONLY $1406.25[/SIZE][SIZE=10pt]
($0.45/watt) [/SIZE]
[SIZE=16pt] [/SIZE]
(Regular Price: $3125.00)
Manufacturer: Stion
SolarModel: STL-125
Maximum Power: 125 Watts
Max (Vmp): 41 Volts
Max (Imp): 3.05 Amps
Open Circuit (Voc): 55 Volts
Short Circuit (Isc): 3.45 Amps
Pallet of 25
130 Watt 48 Volt Solar Panels
Stion STL-130
Only $1462.50($0.45/watt)
(Regular Price: $3250.00)
Manufacturer: Stion
SolarModel: STL-130
Maximum Power: 130 Watts
Max (Vmp): 42.7 Volts
Open Circuit (Voc): 56.5 Volts
Short Circuit (Isc): 3.42 Amps
50 LED Colored (Red, Green, Yellow, Blue) Solar Power Christmas Lights!
[SIZE=16pt]ONLY $3.00 [/SIZE]
(Regular Price: $7.99)
Easy to install, Solar-powered decorating lights are great for decorating the outdoors. They are fully articulated, so you can position your Solar Powered Flood Light in any direction.
- Automatically Turns On at Night
- Needs a full day charge to turn on at night for 9-10 hours.
- No Wiring, Instant Installation
50 LED White Solar Power Christmas Lights!
Only $3.00
