Brain storming
d tree's
May 9, 2009
212
SO Cal
Guys is all that needs to be done is cut 2" of each side of this after piece in the picture or is it down the whole side of the camper , tried to search for an older thread about this subject but couldn't find one ,D
PS missed out on one that said he had it professionally narrowed ?
Aft trim near tailgate ?
The whole middle width portion will be 64" and too wide for modern trucks (its the part by the tailgate but also the upper step portion as you see in the front of the camper that is still inside the bed rails). The main issue is its not just the wood portion that is too wide, the front/rear framing connects to that wood. That would need to be narrowed which requires aluminum work (ie welding). There may be other issues about cabinets/appliances fitting but if you're doing the above work its smaller scope to rework or make new cabinets, etc.
LOL Pods I knew there had to be more to it or more would be doing it ,thank you ,D
