Can you put a solar panel on a Thule roof rack? #2 question below.
TahoeT
Dec 12, 2019
23
Thule model 460 (2017) with two cross bars about 1 1/2 thick. The bars run horizontal and are adjustable. The panel will run from front to back...and probably end up near the middle of the roof.
I plan on using a 160 watt panel on top with two home built lithium ion batteries in the bank. Do I need two BMS's...one for each battery. Thanks for your help. T
I have solar panels attached to my Yakima racks. Thule is very similar.
I used the threaded track nuts (the nuts that hold the towers to the track) to hold aluminum square tubes cut to the appropriate length and then bolted the solar panel frames to the aluminum tubes. Quite strong and low profile. Aluminum "L" channel would probably work as well. I can still use the towers with cross bars to carry items such as kayaks. The tower height puts the crossbars comfortably above the solar panels. See the photos in my gallery.
https://www.wanderthewest.com/forum/gallery/image/18340-solar-panels-on-fwc-keystone/
I assume that the batteries will be connected together into a single battery bank, in which case you only need one battery monitor. I use the Victron BMV-712
I am not as familiar with Lithium Ion batteries as I am with lead acid but it is my understanding that Lithium Ion batteries typically have built in battery management systems.
I hope this is somewhat helpful,
Craig
Hopefully someone more knowledgeable, such as Rando, will comment.
I am wondering why you are planning on two LiFePO4 batteries? If you are home building them, why not just build one to the capacity you need? There are CALB cells available up to 400Ah per cell, so I am sure you can make one big enough. Even if you use smaller cells you can put them in parallel/series so that you only have one 'battery' and therefore one BMS.
Thanks Rando. I am looking at several 180 to 200 amps on Alibaba. Prices are pretty good and the reviews are also...if you can trust them. T
One reason to have two: I used 2 in parallel to get sufficient Amp capacity out of them to run my 1800w induction cooktop. Each BB can only put out 100A, so I needed two. I checked around and didn't see any 100AH batteries that could output more than 100A.
Thinking of purchasing this battery. AliExpress: Any members have a review? 4Pcs 3.2V 190Ah Lifepo4 Battery
BLS BATTERY OFFICAL STORE
4PCS-NEW-3-2V-190Ah-lifepo4-battery-LFP-lithium-solar-4S-12v200ah-cells-not-100Ah-for.jpg_220x220xz.jpg
Please disregard the above battery review. I did some research and found some questionable issues with the company. I do not plan to purchase that battery.
