I'm helping MikeDahlager repost some info he had posted in a Yahoo group.
Hello, well it's done and it was one heck of a chore. Drained and flushed the whole system with air. And the top lifted for the first time in three years. Robert the hydraulic fluid is rated for all weather. That is the fluid that John Deere adds at the factory for all there equipment. East coast, West coast and all points in between. They use the same fluid. Ted I found out the hard way about filling the system when the top is up.*** I had a bit of a mess with my 8' non cab over. Learning experiences are always fun.
So this is what I did to drain and flush the system. First off I removed the fitting at the furthest cylinder from the pump, which is the right rear and attached a rubber hose to it. I placed a container below that. I pumped the pump until no more fluid was coming out. I then reattached the fitting temporally. Than I removed the fitting at the pump and placed a shop towel around it to catch any oil. Next I loosed and removed the fitting at the left front and used an air compressor to blow air thru the line. When that was done I reattached the fitting loosely and moved on to the next one. Right front, right rear and last the left rear. I then removed the pump from the camper and
turned it upside down to make sure there was none of the old fluid in the reservoir. With that done I reinstalled the pump, hooked up the main line and filled the system with hydraulic fluid. I had left all the fitting a little loose so as when I was adding fluid I was pumping the system to push any air out. When oil started to leak at all four fittings I stopped and tightened them all down. Topped off the reservoir and jacked up the top. As I said it is one heck of a chore, but well worth the effort. It's been a long day and I'm
bushed! Till next time, Harold
Note: In the '01 Op Manual they say--"Bleeding the system is done by running the
pump for 15 seconds in the down position with the gate valve in the
open (or lowering) position."
***Make sure that the top is in the lowered position before you fill up the reservoir! When I spoke to Brian at Alaskan he told me that it is not uncommon for folks to fill it up when the top is up, and then you can imagine what happens when the top is lowered!
