Maybe it helps
Never seen an air head composting toilet in a FWC
Tank needs assisted venting 24 hours a day!
You have to go with a solar powered and battery powered vent (for the night)!
From the air head FAQ:
[SIZE=12pt]“We do not recommend the unit remain installed with the fan disconnected. Moisture and a musty smell will be noticed inside the cabin when the fan is not running for any long period of time. We recommend the use of a small five- to ten-watt solar panel to offset the drain on the batteries”[/SIZE]
