b team
- Joined
- Dec 26, 2006
- Messages
- 252
I had a issue with the in camper battery not charging and the charge gauge and lights always reading low and dim. Sometimes power would be good and other times very weak. I narrowed the problem down to the converter by tapping on it.
I removed the front panel on the sink/stove cabinet and removed the conveter. One of the small bolts that hold the converters PCB to the converter chassis was loose and not grounding. Tightening this fixed the problem.
Hope this helps someone. I do a lot of offroading and washboard roads. I'm impressed that the wood screws and such have held up so well.
