tinycamper
- Joined
- Jul 5, 2022
- Messages
- 1
2004 Tacoma 3.4 V6 – 2012 FWC Eagle.
No solar. Trying to include an engine battery assist circuit by configuring 4 circuit breakers. Similar to diagram below, but with 2 circuit breakers where “Manual Switch” is and another set of circuit breakers at the other end.
1. Does the “Normal Chg” circuit look right?
2. Does the “Eng Batt Assist” circuit look right? Is 2 awg big enough? Will it work without risking damage to the Aux Batt due to excessive discharge current?
3. Open to all comments and suggestions on the circuits, wire gauge, circuit breaker values, and any component selection ideas.
I’ve been away from these forums for quite a while, but I’ve read some of the Electrical Power posts and this is my best shot. Thanks for any help.
120-amp Alt => Eng Batt (2 awg) => Split #1 (Normal Chg) => Circ Brk (XX amps) =>
=> Split #2 (Eng Batt Assist) => Circ Brk (XX amps) =>
15 ft-2 awg => Anderson Neg (2 awg) => Aux Batt / Anderson Pos (2 awg) => Split
Split #1 (Normal Chg) 6 awg => Circ Brk (XX amps) 6 awg => DC-DC (XX amp) 6 awg
=> Single Aux Batt (SOK 200 AH - LiFePO4) => SOC Batt Mon
Split #2 (Eng Batt Assist) 2 awg => Circ Brk (XX amps) 2 awg => Aux Batt
