DC/DC Charger Location
CPT Davenport
El Pescador
Dec 18, 2021
717
Davenport CA
I have been hanging on to a Victron 30amp DC/DC chargers for a year now. After some close calls with only solar last winter and limited sun, I'm finally gonna install the little rascal. I'm worried about it getting too hot if I put it in the existing battery cabinet (Hawk side dinette). Would it be crazy to instal it in the passenger side, front turn buckle door???????? Mounting it just on the other side of the camper wall from the battery which would make a short run. It seems like it may be out of the elements for the most part tucked away between the camper and the bed wall.
Too wet out there and a bad idea?
I have mine installed in my battery compartment in the camper. It has never gotten even slightly warm. But my tundra has a smart alternator, and it seems that after a half hour of the truck running, the Orion never puts out more than 150W, which is disappointing. But ymmv.
I would hook it up temporarily with a low battery and let it charge and measure the temperature of the unit. I have been reading the Victron and Renogy manuals recently and they do specify a minimum clear distance. While open air flow is best, the manuals suggest to me that if the compartment is big enough it should be OK, if not, a small fan could be added to vent to outside air. That said, they do have overtemp shutdown just in case.
I've got the smaller 18amp charger mounted in a flatbed hawk and thus in a confined space. I've not checked to see how warm/hot it gets when driving but I haven't seen any degradation of the charging and will try to remember to check it next time on an extended road triop.
Good information all. It was my understanding that in bulk charge they get really hot. Things are pretty crowded in my battery cave with the new 200ah lithium hogging up space. It is good to know they have an overheat shut off. I will look back at the recommended minimum clearance and see if I comply.
Where have others with a side dinette Hawk placed these units?
The safety instructions in the Victron Orion manuals say not to operate it in a wet environment, and the specs say its humidity withstanding capability is 95% non-condensing. I would not install it on the outside of the camper even where well protected in the truck bed.
Don't know if this helps, but these were my installations in a Hawk with a side couch configuration, and one in a Hawk with the front dinette.
Thank you for that information. I think that location would be too wet as well.
Thank you. I'm going to go with the same location as you posted. Unless anyone else has any better locations to suggest.
I have side dinette and battery box is full so I hung it on exterior wall of Battery box ...an ideal spot. When one sits down it is behind your knees so no contact.... wires are short (12") into Battery box. But the real plus is cooling... it is perpendicular, next to the access drop open door for turnbuckle. So when driving I leave that open. it is inches away and has lots of air flow.
Great idea!
In case you didn't notice, I also mounted the Orion on 1" standoffs which allows a lot more airflow around the heatsink. For the side couch system I drilled 4 air vents to the outside. For the front dinette installation, I added a thermostatically controlled muffin fan which exhausts through a hole in the sidewall. But it has never come on, which is why I didn't bother for the side couch installation.
I see that and did the same thing on my charge controller. I think it helps. I will also add some vents in the cabinet near the front passenger turnbuckle door. I have vents in my TB doors and will open them while driving if she heats up. Should be sufficient flow and cross ventilation. Great ideas here, thanks all!
