Digital Thermostat - Honeywell RTH2300B
mynxd
Feb 17, 2012
68
West Vancouver, BC
I recently purchased this item ($32.98Cdn) after breaking the glass thermometer glued inside the cover of the Atwood thermostat which came with my camper. This item is in US Home Depot $26.23, and on E-bay for $8-$20 (some with free shipping).
I am very pleased with the way it works. Outside temps have ranged from 32F to 42F over the past 4 days, and it has controlled the temp inside the camper between 55F and 62F while I have been making/modifying some inside storage cabinets.
Installation
I tested the polarity of the 2 blue wires on the old thermostat. The positive side blue wire was connected to the R terminal and the other blue wire was connected to the W terminal. Due to the sixe of the blue wire, I had to remove the jumper wire between the R and Rc terminals supplied with the thermostat.
This is interesting, is that a Hydrotherm furnace? I am installing a 16kbtu Hydrotherm in my Alaskan, but bought the simple Atwood because I was not willing to part with $165?? For the digital one. I had read that a residential digital would not work-didn't understand why, a closed contact is a closed contact(unless some are solid state switches?)
Based on your results I will try the same one.
Thanks for taking time to post.
Any battery operated not battery back up electronic t'stat should work as long as it is rated for a millivolt system.
