Cummins_Expo
SOLD
I have what appears to be a 2006+ Eagle 4 wheel camper. It has the newer windows that open from the inside, wiring behind the lift panels ( pre wire solar ) Maybe? The camper has always been store inside by the previous owner. So the exterior is perfect. Tent is in great shape as well.
It was set up for a bigger truck with jack extensions and spacer on the bottom. But with a drill and 5 mins could fit back into a 1st gen Tacoma. The interior is in good shape. He did a nicely done but basic interior build out. Galley on driverside, bench with storage on the right (DIY not factory)
Has 12v system with battery in camper but doesn't have wiring to plug into truck. So you could it or just use it as I have stand alone and charge up before you go. There is a spot that fits a cooler or a chest style fridge with a 12v outlet wired in.
SOLD
I was using this with a Ram 1500 But now we are going bigger and Alaskan. Located in Prescott AZ.
SOLD
