Entry Ladder Mark I Rev B
rando
Aug 26, 2013
1,638
Colorado
When figuring out the layout for our camper, I struggled with the entry ladder situation. The side door on the flatbed is a little higher than the door on the slide in camper, and entry/exit from a FWC is already a little awkward due to the hobbit door. I spent way too much time perseverating on this, but eventually came up with a pretty good solution - half of a 'little giant' step ladder. This provided, large, flat, grippy and stable stairs - perfect for backing out of the camper, after dark with two beverages in hand. These have worked pretty well over the past couple of years, and I think a few others have adopted the idea:
full
Unlike some of my other ideas, this one worked pretty well first time, and hasn't needed a complete redesign. But there was some room for improvement. The first issue is the length of the ladder. I have the 4-step model, and on flat ground it was a tad too short - not a huge deal, but this did give the steps a slight downward slope away from the camper. On uneven ground this could be pretty significant slope (particularly with leveling blocks under the wheels) leading us to use a 2x4' under the feet to make it more level, and sometimes rocks and logs and whatever else was at hand. This did not contribute towards my goal of a stable ladder, or help with the evening beverages. So revision B of the ladder includes adjustable legs, short mode:
full
Long mode:
full
The tuning used in the ladder is an odd size (neither metric or imperial), but luckily the now removed 'safety rail' is the same size tubing as the legs. I machined up two pegs for each leg, drilled a series of holes in the tubing from the rail, added a some M6 threaded knobs to hold the leg extension in place, and moved the rubber bumpers to the new legs. This gives 6" of adjustability for each leg.
The other issue was the attachment to the side of the camper. The previous system fixed where the ladder was attached. The new system uses a section of always-handy 80/20 bolted to the flatbed below the door. I milled down some U channel to make J channel which grabs the top slot in the 80/20:
full
full
Now you can slide the ladder a couple of cm left or right for when my excellent parking job places a ladder foot right on top of a rock/root/wildflower.
The whole thing folds flat and stores in the under tray drawer:
full
Wow, mine is not even close to that - maybe 5-6lbs. It is all aluminium.
Hello Rando
I'd have to say that looks pretty sweet. I'm still not totally ok with my little step stool. I can not reach our windows w/o standing on the top of a two foot step ladder. How do you get to yours? I also like the way you attach, I have seen that extruded aluminum web site an the uses are only narrowed but your mind.
Russ
This is only half the original ladder - so it only works with the mount on the door. I have never tried reaching the windows (FWC windows open and close from the inside) but I guess you could add an 80/20 rail on both sides of the flatbed so you could reach the windows.
Yep Rando mine open from the inside also, I was referring to the out side blackout / storm flap. On ours I think the windows are up a little higher. Aside from the 4x4 truck, taller side bed rails the cab is a little higher I think. I can sit on the couch with the top down and still have room over head. So outside from the ground those windows are up there.
Russ
The blackout / storm flaps open and close from the inside on FWC as well - which is why I have never considered how to get to my windows from the outside.
I have the 3 step Little Giant for my std slide in Hawk. I removed the safety hand rail and caster wheels on mine. Best steps in the world. Super sturdy, and the dogs can easily use them too.
Nice piece of work. As I was reading your posts I was wondering where/how you were going to store it then you show the pull out drawer. That is definitely one of the many benefits of a flat bed!
Hijack warning!
Somewhere I read about ladders (not step ladders) that fold up into a compact -- long and thin -- shape for carrying on campers/rv's. Can someone point me in the right direction for those?
Very nicely done, Rando. I faced the same problem with my aluminum ladder into my flatbed Grandby. But being basically lazy I just bought an extra set of those nesting orange levelors (can't remember what they are called) and slip 'em under the offending leg(s) as needed. Works very well!
Hey Steve.
The aluminum ladder you provided with the flatbed Hawk I drilled out the rivets and shorted the length to have a steeper angle. It has been working out flawlessly. If the surface is uneven I just kick out the high side to be more level
I do like rando's ladder and would have copied it if you did not provide the one I have.
pvstoy said:
... I drilled out the rivets and shorted the length to have a steeper angle. It has been working out flawlessly. If the surface is uneven I just kick out the high side to be more level...
I would have eventually done the same, Patrick. Sioux never liked it that long.
I hope you kids are well...
