Exterior Amber Light?
May 30, 2020
22
S. California
Love the FWC & this site but have little mechanical skills therefore the question: The exterior amber light failed last year - replaced the bulb then ordered/installed a new unit. It only worked for a moment - any thoughts/suggestions? Is there a fuse for this light?
Those fixtures aren’t sealed and are susceptible to dust intrusion which can cause the switch to stop making good contact. You can often resurrect them by spraying the switch and electrical contacts with contact cleaner.
Yup, this was the case with mine. Cleaned the switch and it was good as new.
Mine is grounded to the siding. Crappy way of doing it. Leads to lots of bad grounds but its "easy". If they're still doing it that way just tightening the bonding screw should do it.
Latest posts
