fantastic fan questions
bob welsh
Nov 15, 2011
27
It seems alot of folks like the fantastic fan . My question is how does the refit go and can you fish wire through the roof fairly easy? Thanks, Bob
I can't speak to the 4WC but the ATC standard vent is wired for a powered fan.
So are, to my chagrin, the Phoenix's. doh!!
Directly behind the fan location in the alaskan is the main power distribution box...you can feed wire through to that distribution box and power the fan from there.
I installed 12v computer fans in the screen area between the screen and the plastic cover...they work sufficiently and don't hog alot of battery...they remove cooking moisture nicely and haven't loaded up on me yet...7 years installed now.
the fans are switched with a blue lighted switch on the face of the power panel
My 2004 Alaskan had 12 volt power to the roof vent. Fantastic fan is worth while.
