Ok I had another thread an I said I would start a rebuild one once the Alaskan was home.
So here it is.
Just got it home on the M101a2 trailer.
Spend today building this dolly to mount it on and then did just than and moved it into the Garage ) no pic but that is coming tomorrow).
Dolly is built from 2x4 and 2x6 with 4 x 6" wheels capable of 800 lbs each.
All 4 wheels swivel. While some do not like this, for my garage it is perfect as I can move it with ease. the removable trailer hitch makes it super easy to back in with a vehicle. Once in 2 people can steer it around very easy for the perfect position.
Also found some paperwork dating back to '78 including a receipt with what Alaskan calls is in and out webbing (Pirelli seals?). Also included new o-rings (from '78) I will still order new ones from Alaskan. Also 3 example seals (kinda neat, all those are pic are coming soon)
Included a checkout list, the O-Ring repair instructions. I will scan both of these tomorrow.
And the proper way to bleed the rams.
That is attached and I will also scan that one in (it is only a picture for now)
So a little surprise.
So far I know the Jack is leaking around the pressure release valve, I need to look if this is a seal or can be replaces. Not sure where else but I will pull it this week and have a look.
So here it is.
