Huckleberry
- Joined
- Feb 18, 2021
- Messages
- 10
Hello!! First timer here. I recently bought a Four Wheel camper to go on the back of my 2003 tundra access cab. The camper is a 1996 hawk model. At first my truck sagged beyond belief even with the blue sumo springs, which worked great for my previous set up. So after debating the black 2500# sumo springs, archive garage leaf springs, and Firestone airbags I finally made a decision and went with the airbags paired with day star cradles. On my first outing I experienced airbag failure due to improper instal after that I decided to add a skyjacker add a leaf from firstgenoffroad to help support the weight of failure ever happened again and to add a little lift. The skyjacker add a leaf claims 2 inch lift. After that to gain the lift and support the load I was running pretty high psi in the airbags close to 60psi. Next step I added two inch spacers underneath the cradles which in turn allowed me to run 20 to 30psi to support the load. Now finally to my question.
Does having the
Does having the
