For Sale Granby Four Wheel Camper
bryangwesterman
Mar 11, 2015
4
This Camper is Sold
For Sale 1994 Granby model Four Wheel Camper in excellent condition. Stored inside whenever not in use. Includes 3-way refrigerator/freezer, furnace, two burner propane stove top, sink with water and hand pump (can be converted to electric), 120 volt outlets. sliding front window, storage cabinet on front driver side with 12 volt outlets, 3 piece table set, extended cab over bed queen size plus, mechanical camper jacks, 20 lb propane tank, storage cabinet over side bench/bed, screen door. Wired for external battery and has Yakima carrier bases on roof. Pictures available on request. Asking $4,000.00 OBO. Located in northern Minnesota. Call 218-444-5747 or reply to post.
I am in the market for a FWC, and new to the hobby. Can you tell me what the base weight of the camper is with the options that you have on it? What truck do you run with it?
Thanks
the weight for this model as it sits is 890 pounds. The best way to check what truck it fits on is to go to the Four Wheel Camper we site as they have a fitting section. It is made for a 8 foot box truck. In order to fit on some of the newer pickups you may need to use a 2X4 frame
Thanks for the reply. My truck box is 6'6", so I'm thinking the granby my not work.
A Grandby works just fine on a short bed by leaving the tailgate down. I've had a 1996 Grandby on my short bed Dodge over 6 years without problem. You just need to find out if an older Grandby will fit your truck depending on the year and what kind of truck you have.
