Four Wheel Pop-up Camper (2006 Eagle) $11,000
hsheppar
Nov 22, 2014
2
[SIZE=18pt]Four Wheel Pop-up Camper (2006 Eagle) $11,000 - SOLD[/SIZE]
[SIZE=14pt]The Eagle is a discontinued model that fits perfectly in a 6 ft bed Tacoma and several other small PUs. See FWC web site (fourwh.com) or call FWC for info about fitting other small pickups.[/SIZE]
[SIZE=14pt]Standard factory features[/SIZE]
[SIZE=12pt]All Aluminum Flex-Frame[/SIZE]
[SIZE=12pt]Jack Brackets (steel)[/SIZE]
[SIZE=12pt]Extended Cabover Bed w/ Mattress[/SIZE]
[SIZE=12pt]2nd fold over bench seat/bed[/SIZE]
[SIZE=12pt]Formica Counter Tops[/SIZE]
[SIZE=12pt]Portable table[/SIZE]
[SIZE=12pt]Fabric Cushions[/SIZE]
[SIZE=12pt]Privacy Curtains[/SIZE]
[SIZE=12pt]Screen Door[/SIZE]
[SIZE=12pt]Stainless Kitchen Sink[/SIZE]
[SIZE=12pt]2 Burner Propane Stove w/ Cover[/SIZE]
[SIZE=12pt]3-Way Refrigerator, 1.9 cu.ft. (AC/DC/Propane)[/SIZE]
[SIZE=12pt]Camper Battery System (1 battery, wiring, separator)[/SIZE]
[SIZE=12pt]110V Electrical System with outlets (only works with shore power, no inverter included)[/SIZE]
[SIZE=12pt]30 amp Power Converter w/ IQ4 Smart Charger[/SIZE]
[SIZE=12pt]12 Volt Outlet[/SIZE]
[SIZE=12pt]LED Interior Lights[/SIZE]
[SIZE=12pt]LED Outside Porch Light[/SIZE]
[SIZE=12pt]20 lb. Propane Tank[/SIZE]
[SIZE=12pt]Forced Air Furnace w/ Analog Thermostat[/SIZE]
[SIZE=12pt]Pre-wired for Solar[/SIZE]
[SIZE=12pt]Fire Extinguisher[/SIZE]
[SIZE=12pt]LP/CO Detector[/SIZE]
[SIZE=12pt]Smoke Detector[/SIZE]
[SIZE=12pt]12 Gallon Fresh Water Tank[/SIZE]
[SIZE=12pt]Large Rear Wall Window[/SIZE]
[SIZE=12pt]Safety Exit[/SIZE]
[SIZE=12pt]Roof Vent[/SIZE]
[SIZE=12pt]Insulated Side Walls & Roof[/SIZE]
[SIZE=12pt]Rugged Vinyl Side Liner[/SIZE]
[SIZE=12pt]Aluminum Exterior Sides[/SIZE]
[SIZE=14pt]Additions/enhancements[/SIZE]
[SIZE=12pt]140W solar panel with charge controller[/SIZE]
[SIZE=12pt]On-demand water pump (pressure activated) and upgraded H/C faucet[/SIZE]
[SIZE=12pt]Plumbed for hot water inside and out – external tankless water heater[/SIZE]
[SIZE=12pt]Mechanical Camper Jacks (4 corner), with wheels added for easier camper removal/installation[/SIZE]
[SIZE=12pt]Steel Jack Extension Plates (rear - for truck with dual rear wheels)[/SIZE]
[SIZE=12pt]Porta Potti[/SIZE]
[SIZE=12pt]2nd larger interior table (a bit funky but works for inside dining)[/SIZE]
[SIZE=12pt]Mechanical (drill-driven) lift assist[/SIZE]
[SIZE=12pt]Additional over-cab storage bins (space between cab roof and camper - use depends on height of truck cab)[/SIZE]
[SIZE=12pt]Backup camera[/SIZE]
[SIZE=12pt]Wheeled platform for off-truck camper storage[/SIZE]
[SIZE=12pt]Excellent condition! Currently installed on a 1991 Mitsubishi 4x4 V6 Mighty Max truck, which has a bad transmission. Camper and all extras - $11,000. Camper is located in Berkeley, California. If interested in repairing the truck, will include it for an additional $1,000. For questions or an appointment to view, call 925-518-8871.[/SIZE]
Hey WTW community,
I live in Colorado and I am a high school teacher that can't get away very easily. I am wondering if there is anyone that is near this Eagle that could possibly check it out for me? If you can then please let me know. Thanks and have a great Monday!
Mike
Longmont, CO
