Mike from Canada
- Joined
- Apr 17, 2018
- Messages
- 14
Hi all, I have a stock 3 way fridge in our Raven. Just wondering from your experiences when I should be running the fan? All the time? When it's hot? Any guidance is appreciated!
I use the same solution. Velcro-ed it in the vent area...Oilbrnr said:If you have the room, I've found that those little battery powered fans on the inside of the fridge (3-way in particular) do help too. Bit more even cooling. They'll run about 30-45 days on a couple D-Cells.
Link
I actually use in both areas. LOLOilbrnr said:Well, I meant on the inside of the fridge. But they could work outside too!
