Oryguntroutbum
Plugging away on my 64. Found some dry rot on the lower corner of the driver side front wall. About 8" x "8 damage. I'm thinking about replacing the front wall unless someone has a suggestion about how to repair it. It's not necessarily anything hurting the structural integrity.
If I do replace it, it looks like the only screws I will need to mess with to get the panel off would be the two screws at the top of the lift rail and the single screw/nut in the middle of the lift rails. Am I correct about this?
Thanks in advance.
Chris
Thanks in advance.
Chris
