FWC and ATC Comparison (what are the differences ?)
Stan@FourWheel
Jun 4, 2007
2,380
Woodland, CA
*Update Message* 10/20/2009
Some of the most recent changes we are excited about ...
Eagle, Finch, Falcon, Fleet, & Ranger Model now have 6' 4" of interior headroom.
The Finch, Eagle, Fleet (wide body eagle), Hawk, Kestrel, Ranger, Grandby, & Keystone Models all have a 22 gallon fresh water tank now !
Most all of our camper models have room up under the front couch / settee for 1 or 2 deep cycle batteries. We have made extra room because many of our customers these days are wanting dual camper batteries.
We now have a "wide body eagle" model available for customers that might want a little extra room inside their camper. The Eagle Model is 69" wide. The "wide body" Eagle Model is 75" wide.
In the wide body Eagle Model we can install the hot water w/ the outside shower option now. So if you have a small truck like a Tacoma, we can now put hot water & an outside shower on it. Yea !
We are using 6 gallon aluminum hot water heaters now. No anode rod required. These new tanks hold more water and are lighter than the older hot water heaters.
We are installing hot water bypass valves and a low water drain in the campers that have the hot water system. So if you want to easily winterize and not fill the hot water heater beacuse the weather might get below freezing, it is very easy to winterize the camper now.
We are now offering a small opening drivers side window on the Ranger, Grandby, and Keystone Models.
We are now an authorized distributor for the Engel refrigerators and can install the Engel coolers in most any of our campers if the customers would prefer this over a 3-way refrigerator. Please call or e-mail for current prices.
We can now install a 2-way "compressor" refrigerator/freezer in most all of our campers if the customer would prefer this over the 3-way gas absorption style refrigerator. Please call or e-mail for current prices.
We are installing a high quality 30amp marine plug on the side of the campers so you can hook the camper into your garage, generator, or shore power when available. All the campers (except the shell model) come with an IOTA 30amp power converter inside the camper as standard equipment.
We now have 4 different fabric colors available for the interor couch & bed cushions.
All of our kitchen cabinets and small storage cabinets are now hinged and can be pulled or flipped open. We don't use any of the slider cabinet doors any longer. We found the slider cabinet doors just didn't slide as well as customer wanted.
Most all of our campers now have a LED entry light to provide comfort and easy of entry into the camper as you get inside. Once inside the camper you can then turn on the interior lights.
We are now using a nice Wedgewood propane cook stove. This new stove has one large burner in case you have a big frying pan, and the second burner is the average size. This gives you more cooking flexibility depending on the size of your cooking pots and pans.
In all of our new campers (except the kestrel model) we are now using 2 smaller 10 lb. propane tanks. These tanks are much easier to find locally if you need a spare or a replacement. They will give you more flexibility on how you can use them. Customers seem to be really excited because they can now leave one tank in the camper to run propane item, and they can easily use the 2nd tank outside to fuel the outside camp stove, bbq, lantern, etc.
We have switched over to a 12,000 btu furnace in all of our models. It uses very little battery power to run the fan (the benefit ... your aux. camper batery will last longer) and the new furnaces are quieter than the old Suburban and Atwood furnaces we have used in the past.
We are offering 2 different couches for most all of our models now. We can install the original L-Shaped roll over couch bed, or we can install the new Dinette style with 2 seats facing each other and a table in the middle. There is no cost difference between the 2 styles of couches.
On the Hawk, Grandby, Kestrel, and Keystone Models we are installing quality LED running / marker lights on the outside of the campers. This will help to keep you safer while traveling at night.
We have a gas strut list assist available now for all of our campers. This is a nice feature if you are having a hard time raising the camper roof, or if you are planning to leave a little gear on the camper roof and need just a little extra help from a simple roof list assist. We can install this on any new or used FWC camper.
All of our campers are now being constructed with a very modern interior for the walls, couch, & cabinets. We felt the older style Western Oak (oak wood grain) was getting a little outdated. Customers were commenting that the oak grain cabinets looked old. We are now using what we call a "Birch" interior. It is just a little lighter, and has a much more modern look to it.
All of the new campers coming off the production line will come standard with dual 12v outlets at no additional charge. With todays modern society, we found customers are wanting that extra 12v outlet for running items like a laptop, dvd player, or recharging their cell phone.
In the next few weeks we will have the new "aluminumed framed" cab-over (hard side) campers available for order. So if you might be looking for a light weight cab-over camper and just are not wanting a "pop-up" style camper, please call or e-mails us. We will have these new hard sided cab-over campers available very soon ! [/color]
http://www.fourwh.com/FWCvsATCcomparison.htm
We are making tons of positive & exciting changes around here that past few months.
If you are looking at buying a truck camper and are comparing the ATC vs. the FWC, you really owe it to yourself to check them both out ! Go see their campers, and then come see our campers. The difference will speak for itself. We keep getting potential customers calling and e-mailing us saying ... "both the FWC and the ATC campers look pretty much the same, why is there a price difference between the two ?". Remember, you usually get what you pay for. Come see us.
Hello everyone on the forums
More and more these days with the WanderTheWest forums growing, we get the same question from people looking ... "what are some of the differences between the FWC and ATC campers, they look so much the same ?"
We put together a quick spread sheet to note the differences we can see between the Four Wheel Campers and the All Terrain Campers.
See spread sheet here ...
Please, please, please ... take this as a positive comparison list, we are not putting this together to bash, only to note the differences we know about.
If you see anything that is not accurate, let us and we will change it ASAP !
Ben and All Terrain Campers build a great product, just different. Either way you go, you will be making the right decision. It will really boil down to what you are looking for in your camper, what you want to use it for, and what suits your needs best for options.
I hope this list helps -- any feed back good or bad is welcomed if changes are needed to the comparison.
Happy Camping !
vs list
Stan,
Thanks for fixing the list. Looks good. We still use the old style vent to keep the profile lower so that some customers can fit the camper in the garage.
I like your vents better but they add a couple of inches to the height. Seems like everything is one trade off for another.:)
Again, appreciate the way you put the list together. Very nice job.
Stan,
The comparison helps those of us who have not seen both campers. (Or either, in my case.) The current version comes across much better than the first, and appears less biased. Not that it was intentionally biased the first time, but now it "reads" better.
On a related note, you both (Ben and Stan) impress me with how well you relate here on the forum. I've worked in the RV industry at the retail level, and can't think of many professionals that act so...professionally. Best to both of you in your endeavors. I'm looking forward to seeing examples of your work on the east coast someday.
Bob
The list looks almost complete
Hi Stan and Ben,
the list looks almost complete, but I think to assure that you covered really every single detail you would have to put both campers side by side.
One detail I am missing on this list are the prices. I put a few months ago a price comparison here:
http://spreadsheets.google.com/ar?id=o11762516598540286466.3837103123247221999.15843673975341149620.4633945287152372796&hl=en&action=1&tile=0&rpert=20&tfe=undefined&srow=0&erow=59&fprt=false&scol=0&ecol=9
The prices might be outdated, but I think a price comparison should also be part of your list.
The tendency of both of your companies is clear. FWC is going after the more comfort oriented camper, ATC is after the KISS fan (Keep It Simple, Stupid).
But then again, the additional 4" width of the ATC doesn't make sense. It gives more room and comfort. But maybe this is the exception to confirm the rule.:rolleyes:
Food for thought.
Hi NJTaco,
you'll see an ATC Bobcat soon on the east coast, but down south in Florida. My ATC should be delivered by Oct/Nov.
Just let me know if you are coming down and want to have a look at it ;)
Hi NJTaco,
My father just bought a condo down there some where...I'm to visit this winter, I hope. I'll try to contact you before we go, and get together. Thanks for the offer.
Bob
Extra width
The extra width was so that we could put a deeper cabinet in the camper. This increased the size of the water tank compared to what we used to do and gives more storage in the cabinet area.
It also increases the size of the bed to be a little more comfortable for two people and allows us to keep the mattress a full four inches instead of splitting it into a 2" mattress.
Other than that, we keep it simple as you state. I have told most people who asks me the difference that FWC offers more options and has more standard on their campers than we do. Not everyone needs all that though and we offer a more basic camper and lets you choose the options you need for the style of camping that you will be doing.
Price wise, if you look at the updated price list, you will find us about even depending on what options you are looking for. In some cases we may be more or FWC may be more. Just depends on how you want to set up the camper. You really can't go wrong with either company and I have lost track of the amount of customers that I have recommended over to FWC because they were looking for something that we just didn't offer. Both companies fill a nitch in the industry and I hope that over time we will still be able to help each others customers in this type of forum.
I've owned both...
And liked both.
I owned a Grandby that was loadED... and was one heckuva camper. I sold it for practically what I paid for it after using it for 3 years.
My current Panther (first one sold) started out as a shell unit with an L couch, table, heater, large windows on both sides a window in the back, sliding front window, 12 V outlet, 110 inverter, extra battery with separate charging, pre-wired for solar, extra steel in the back to bolt stuff to, a "porch" light, and wired/switched for two more lights in the back, vent and mechanical jacks... The two large windows and the one in the back make the camper seem so much bigger and lighter. Great decision. I think that the ATC has a bigger door too.
I agree with what some of the people have said, the ATC is for us KISS people. I went with my unit because... and I've said this before... I've camped, traveled, backpacked since I was a kid and for me the camper serves three purposes. (1) keeps me dry in the rain, (2) keeps my poor old back off of the ground at night and (3) gives me a great place to carry all of my beer, er...camping stuff. Oh yeah and it looks cool.
I cook outside, always. I sleep inside and I'm mostly a fair weather camper. No Alaska winters for this Santa Cruz boy... Once I realized that, I knew that the Grandby was meant for someone who camped differently than I do.
So... check them both out. Talk to the guys in the shops, talk to the owners and go where your gut tells you to.
I've never met Stan, I'm sure he's a great guy and I know it's a great camper.
I know Ben, Marty and Jeff. They are the best. They've helped me every step of the way. They go out of their way to work with me ... even when it's obviously user error. And they know their stuff backwards and forwards.:D
You can't go wrong....
I don't have many pictures yet.
Our dealer in Wisconsin has one in his Grandby (see pictures below).
We opened up the area and installed an extra storage cabinet next to the Engel for him.
On the last camper we just left out the Ice Box so they had a big open area, and then we installed an extra 110/120V outlet and a 12v outlet.
I think it is going to be a nice option for the people that want something other than the 3-way refrigerator.
:D
Some very nice changes stan. Have any pics with the Engel installed?
I logged on to the ATC site and noticed right away that the ATC comes standard with an extended cabover with a 4in, mattress. This is an expensive option on the FWC. Surprised nobody had posted this before.
I don't know exactly how they are doing things over there ?
We have looked at their web site but find it very vague on what comes standard and what is optional equipment.
I see on their web site they charge $ 375.00 to get the slide out for the extended cab-over bed on some models, so that would make it about a $ 200 price difference to have the extended cab-over bed.
I wish I had more information so I could give you a better comparison.
That said, Four Wheel Campers is coming out with a "Classic" model in the next few weeks so we can offer our customers a similar (very basic) camper, at the same or a better price that some of our competitors.
Yea ! More choices and more options for you guys to choose from.
In the end, you (the customer) will have to choose what you like the best, but if you spend 50 - 60 hours a week building, selling, designing these campers like the staff here, you would quickly see some big differences between our campers and other pop-up camper competitors. Unfortunatly the average customer shopping on line won't see most of the differences if they are just looking at prices on line. We know our campers won't be for everyone.
I was looking at the Bobcat vs. the Eagle when I posted the comment about the extended cabover/bed size. I like the FLEET concept of the extra 4 in. width but wish you folks had photos on your site.
So now you mention a new "CLASSIC" model? Tell us more because I like the K.I.S.S. concept. I don't feel like I need a 110 system because I want to camp as far from the Winnebagos in parking lots as possible. A 12 volt system is good for me and I have been researching you guys and ATC partly because I wanted to avoid the 3 way fridge with its leveling hassles and maintainence problems and you guys offer an icebox. I hate the idea of paying for an option I will never use. I was even considering a SHELL model but it would be nice to have running water handy and a stove to make coffee if it's raining.
Can you give us K.I.S.S. folks a little inside info on your new CLASSIC Model? Thanks for the reply post.
soon ... details coming soon ... hang in there
I'm guessing in 2 weeks we will have all of the details for you.
Reading your post on what you are looking for, the "Classic" might be exactly when you are looking for, and it will be at a more affordable price.
As soon as I have the final details & prices from the owner here I will post it ASAP !!
... So now you mention a new "CLASSIC" model? Tell us more because I like the K.I.S.S. concept. I don't feel like I need a 110 system because I want to camp as far from the Winnebagos in parking lots as possible. A 12 volt system is good for me and I have been researching you guys and ATC partly because I wanted to avoid the 3 way fridge with its leveling hassles and maintainence problems and you guys offer an icebox. I hate the idea of paying for an option I will never use. I was even considering a SHELL model but it would be nice to have running water handy and a stove to make coffee if it's raining.
i think that when you do a comparison you need to do it between like products.ie. the eagle and bobcat.the bobcat comes standard with extended cab also slide bed check the web site.its not fair to compare one model from one maker with a different model from the other maker.i visited both companies,FWC first and was impressed with their product.than went to ATC and saw that they made a product same quality but with different standard features.i also like the KISS idea.both companies have a spot in the market.its just personal preference.frank
Just an update on this thread as of July 16th, 2010
Most all of our camper models now come standard with the "extended cabover bed", no additional charge.
The Falcon Model, Finch Model, Eagle Model,Fleet Model, & Ranger Model all come standard with the "Extended Cabover Bed" at no additional charge. You no longer have to pay the $ 575.00 on any new order if you want the extended cabover bed.
The full sized truck mdel like the Hawk, Grandby, Kestrel, & Keystone Model also come standard with the "Extended Cabover Bed" now. It will be a fixed cabover bed that measures 78" x 48" inches. If you want to add the additional 16" slide out with additional cushions to make it the full queen size, you would need ad add $ 375.00 to the price.
Some of the most recent camper changes we are excited about and so you can really see that there are many differences between the 2 brands of campers ...
Eagle, Finch, Falcon, Fleet, & Ranger Models now have 6' 4" of interior headroom.
The Finch, Eagle, Fleet (wide body eagle), Hawk, Kestrel, Ranger, Grandby, & Keystone Models all have a 22 gallon fresh water tank.
All of our full sized campers (Hawk, Grandby, & Keystone) now have enough room under the front couch / settee for 1 or 2 deep cycle batteries. We have made extra room because many of our customers these days are wanting dual camper batteries.
We now have a "wide body eagle" model available called the "FLEET MODEL" for customers that might want a little extra room inside their camper. The Eagle Model is 69" wide. The Fleet ("wide body eagle") is 75" wide.
In either the Eagle Mode or the "wide body" Eagle (Fleet Model) we can install the hot water w/ the outside shower option now. So if you have a small truck like a Tacoma, we can now put hot water & an outside shower on it. Yea !
We are using 6 gallon aluminum hot water heaters now. No anode rod required. These new tanks hold more water and are lighter than the older hot water heaters we used in past years.
We are installing hot water bypass valves and a low water drain in the campers that have the hot water system. So if you want to easily winterize and not fill the hot water heater because the weather might get below freezing, it is very easy to winterize the camper now.
We are installing a high quality 30 amp marine plug on the side of the campers so you can hook the camper into your garage, generator, or shore power when available. All the campers (except the shell model) come with an IOTA 30 amp power converter inside the camper as standard equipment.
We now have 4 different fabric colors available for the interior couch & bed cushions.
All of our kitchen cabinets and small storage cabinets are now hinged and can be pulled / flipped open. We don't use any of the slider cabinet doors any longer. We have found the new hinged doors more user friendly.
Most all of our campers now have a LED floor entry lights to provide comfort and easy of entry into the camper as you get inside. Once inside the camper you can then turn on the interior lights.
In all of our new campers (except the kestrel model) we are now using 2 smaller 10 lb. propane tanks. These tanks are much easier to find locally if you need a spare or a replacement. They will give you more flexibility on how you can use them. Customers seem to be really excited because they can now leave one tank in the camper to run the campers' propane items, and they can easily use the 2nd tank outside to fuel their outside camp stove, BBQ, lantern, etc.
We have switched over to a 12,000 btu furnace in all of our models. It uses less battery power to run the fan (the benefit ... your aux. camper battery will last longer) and the new furnaces we are using are quieter than the old Suburban and Atwood furnaces we have used in the past.
On the Hawk, Grandby, Kestrel, and Keystone Models we are installing quality LED running / marker lights on the outside of the campers. These LED running lights will help to keep you safer while traveling at night.
We have a gas strut list assist available now for all of our campers. This is a nice feature if you are having a hard time raising the camper roof, or if you are planning to leave a little gear on the camper roof and need just a little extra help from a simple roof list assist. We can install this on any new or used four wheel camper.
All of our campers are now being constructed with a very modern interior for the walls, couch, & cabinets. We felt the older style Western Oak (oak wood grain) was getting a little outdated. Customers were commenting that the oak grain cabinets looked old. We are now using what we call a "Birch" interior. It is just a little lighter, and has a much more modern look to it. It is of the same quality. We DO NOT use any press wood or particle board in our campers.
All of the new campers coming off the production line will come standard with dual 12v outlets at no additional charge. With todays modern society, we found customers are wanting an extra 12v outlet for running items like a laptop, dvd player, or recharging their cell phone.
We now have the new, light weight, hard sided, cab-over campers available too !
Other features we have added the last few months:
Removable Front Opening Window available on all models.
We are now using polyfoam insulation on all of our camper models !
Optional 3.0 cu.ft. Refrigerator/Freezer (Hawk, Grandby, & Keystone)
More Drawers & Cabinet Storage on most all camper models.
Solar Panel -- Roof Mount -- 85 Watt w/ controller [Available on All Models]
<<< i think that when you do a comparison you need to do it between like products.ie. the eagle and bobcat.the bobcat comes standard with extended cab also slide bed check the web site.its not fair to compare one model from one maker with a different model from the other maker.i visited both companies,FWC first and was impressed with their product.than went to ATC and saw that they made a product same quality but with different standard features.i also like the KISS idea.both companies have a spot in the market.its just personal preference.frank >>>
I'm a bit confused on the slide out for the Eagle, Finch.
I assume that it comes standard? What are the dimensions of the beds with and without the slideout in use. I'm thinking something like 75" by 67" (Eagle) and 75" by 73" (Finch). This would make the slideout 37" long and the extended bed 48" long. Four inch cusions?
The front opening window is not standard, correct?
Thanks for your help!
here you go ...
(see attached picture)
The Fleet Model will have the same measurements, but the cabover bed will be 6 " wider.
All camper built with the "extended cabover bed" will have the 4" thick bed mattresses.
I will try and put together a better description in the next day or two.
I have a few other things that I have to get done today.
Wow stan. It looks as if all of the posturing and "my camper is better than your camper" talk that pervades this board in the ATC vs. FWC comparison has paid off big for the FWC crowd.
Now if you just can learn to bow down and kiss their feet you might make a few sales (just kidding...but not really....sheesh)....
Thanks for making a great camper and for listening to the needs of you customers.
mtn
