FWC Moving
Barko1
Aug 20, 2008
1,635
Southern Appalachians
Four Wheel Campers is on the move, literally. Not only are they making some important changes to their time-tested truck camper roof design, but they’re also picking up everything and moving to a much bigger factory. Did we mention this new factory is big? It’s big!
Talking with Tom Hanagan, President of Four Wheel Campers, we could hear his excitement. Of course he wouldn’t tell us about the big move until everything was signed and done for fear of “jinxing the deal”. Tom would just say, “I have some really big news, but I can’t tell you yet”. If you want to know how to keep the Publisher and Editor of Truck Camper Magazine in suspense, that’s how. Even Harley was on the edge of his tail.
There’s another even bigger story here. As we talk to our industry leaders, they’re all very excited about 2011. More importantly, they are aggressively buying new equipment, stocking materials, and hiring, hiring, hiring to meet the increasing demand. It’s clear that not everyone is enjoying a recovery yet, but are we getting back on our feet? You’re darn right we are.
TCM: What brought you to develop a one-piece aluminum roof?
Tom: It was time. With our old two-piece roof, the screws can potentially loosen up if the owner doesn’t reseal. Another challenge with the old two-piece roof is that our aluminum supplier had difficulty getting the roof skin to lay flat. Those two issues were big motivators to go to a one-piece roof. Now we don’t have to worry about the roof being flat or the screws potentially backing out. And the fit of the skin on the roof is significantly better for structural integrity.
TCM: For anyone with an older Four Wheel Camper that features a two-piece roof, how can they prevent the screws from potentially backing out?
Tom: Four Wheel Camper owners with two-piece roofs should periodically do a visual inspection to see if any of the roof screws have started to back out. If they have, tighten the screws and put a dab of silicone over the screw to reseal it. This does not happen often, but it does happen. With the seamless roof, there are no screws to potentially become a problem.
TCM: Tell us about the research and development process for the new one-piece roof.
Tom: Locating an aluminum roll that was 100 inches wide was difficult. Most aluminum rolls are 48 inches wide. Eventually, our supplier was able to find a special source for 100 inch aluminum rolls.
The aluminum roll weighs 4,000 to 6,000 pounds and presented it’s own set of challenges. As a solution, we came up with a special roller mechanism using trailer axles and tires together with a rack to accommodate the weight of the roll. The roller mechanism and rack prevents the aluminum from deforming or buckling during production.
The next problem, how to attach the new aluminum skin to our roof frame, was even more difficult. During our research, we reached out to 3M and they recommended their VHB Tape. 3M VHB Tape is a urethane type sealant in tape form. It’s designed to bond two surfaces together and is common in the trucking industry. If you see a tractor trailer with no rivets along the side it’s likely to be using 3M VHB Tape.
The aluminum roof frame construction is the same as it was before. We have added some improvements with the wiring and we changed our insulation to a better R factor styrofoam about three years ago.
TCM: Why aluminum for the skin? Why not use a composite like fiberglass or carbon fiber?
Tom: Aluminum is a tried and true medium. It’s been around forever and it’s light and durable. While we’ve certainly looked at composite materials, our jury is still out as to how well they would work with Four Wheel Campers.
TCM: Does the new aluminum one-piece roof weigh less than the old roof?
Tom: The weight difference is insignificant. The new one-piece roof is essentially the same weight as the original two-piece roof.
TCM: How has the aluminum roof changed the camper manufacturing process?
Tom: We had to change our manufacturing sequence slightly, specifically when we lay the skin onto the aluminum roof frame. Overall, it’s been a minor change. Now we have it down to a science and the new one-piece aluminum roof skin is completed in about the same time that the two-piece roof was.
TCM: Does the aluminum one piece roof allow for options like solar panels?
Tom: It’s now easier to install options because we don’t have roof seams, and we continue to offer solar panels, roof racks, fans, and satellite radio installations.
TCM: Can people who own older Four Wheel Campers come in to get the new roof?
Tom: Absolutely. They can either have their existing roof refitted with a one-piece aluminum skin, or get a completely new roof, roof frame, lift panels, and vinyl side-wall.
TCM: How does a Four Wheel Camper customer know if they should just get a new aluminum skin, or if they need a whole new roof?
Tom: We recommend the new roof option for Four Wheel Campers over ten years old. It’s a good opportunity to renew the camper and give it new life. If you have questions, give us a call and we’d be happy to discuss it with you.
TCM: How much do these roof replacement options cost?
Tom: We’re looking at $4,500 to $5,000 for a whole new roof. For a new roof skin, it will be done case by case, but it will be significantly less expensive.
TCM: Has the aluminum one-piece roof changed the price of Four Wheel Campers?
Tom: No. This has not added cost to the customer. Every Four Wheel Camper is now made with a one piece roof. We’ve been making the new roof for six months and have found that it works very well.
The new Four Wheel Campers factory
TCM: How are things going at Four Wheel Campers?
Tom: Lots of big things are going on. For one, we’re moving! We just signed a lease for a factory several times larger than the facility we’re currently in. There will be more news, but not yet. Business has continued to be very dynamic. 2010 was our best year ever, and our order log is very strong, including numerous export orders in process. The new plant will allow more implementation of our research and development, as well as expanding the production lines and having more room for equipment.
TCM: Congratulations! That’s very exciting news. Are you hiring?
Tom: We are absolutely hiring. We’ve increased our production team by about 20% over the past few months and we’re looking to hire even more people soon.
TCM: We can’t wait for the further announcements. Thanks for keeping us in the loop Tom.
Tom: You’re welcome. And I’ll send you pictures of our move once it’s completed. It’s going to be a big year for Four Wheel Campers.
For more information on Four Wheel Campers, visit their website at www.fourwheelcampers.com.
For more Truck Camper Magazine articles on Northwood, visit www.truckcampermagazine.com/fourwheelcampers. To join in the discussion about this article, go to our Facebook or Twitter page.
Its going to be alot of work to move the factory, but an exciting change.
We need more room to expand in the future.
We are busting at the seams here in our smaller warehouse.
The good news is we have at least 2 months to starting moving most of our stuff in to the warehouse, so the final move will be quick and will happen over a 3 - 5 day period.
We have many extra parts, pieces, compressors, racks, welders, etc. from our old Six-Pac factory and this is allowing us to set up the new factory ahead of time without disturbing our current production line or offices.
The owner of the company here has been trying to stay lean and mean financially so we don't expand too fast and spend too much money only to get spanked by something unforseen (like a another recession).
He is setting the company up to be around for a long time.
The warehouse lease rates are 1/2 of what they were 10 years ago, so we would be crazy not to move since our current lease is up in March.
We are going from 20,000 sq.ft. to approx. 68,000 sq.ft. and with some outside parking lot as well.
It will be a good change. Plenty of room to grow and work on new ideas and new projects.
We will starting building the Six-Pac Campers again plus some other totally new camper designs we have been sketching out over the past few years.
Wish us luck with the new move.
Thanks for your patience while we make the transition.
Happy Camping !!!
Sounds good Stan. I can help you with the move. Just ship me one each window knob. Broke mine (its not a good tie down point btw).
Yes, we are staying here in Woodland.
We are only moving down the street to ... 109 Pioneer Avenue.
(this is near the corner of Main Street and Interstate 5)
It is actually an easier location to get to for our customers and you can kinda / sorta see us from the Freeway.
For anyone that knows where the original Four Wheel shop was (at the corner of Pioneer & Main St), we are just down the street a block as you go under I-5.
http://www.fourwheelcampers.com/contact.htm
yahoo map ...
http://maps.yahoo.com/maps_result?ard=1&q1=109+Pioneer+avenue%2C+woodland%2C+ca&fr2=sc-sb&fr=yfp-t-701#mvt=m&lat=38.681554&lon=-121.746667&zoom=14&q1=109%20Pioneer%20avenue%2C%20woodland%2C%20ca
Are you staying in the same city?
Hey Stan, how about a "legit" camping spot at the new factory for us customers passing through?
Best of luck with the move, I hope that this is the catalyst that will bring FWC innovation, design and materials into the 21st century. :)
