FWC Price Increase Coming on Dec. 1st, 2015
Stan@FourWheel
Jun 4, 2007
2,380
Woodland, CA
Hello WTW Members
There has been some questions on how much the price increases will be coming Dec. 1st.
Thought I would post the pricing details below for anyone that might be thinking of placing an order sooner, rather than later.
If you are thinking about getting a camper for Spring, now is a great time to order.
You will save some $$ and still get your camper by the time you need it / want it.
Last year we got about 70 new orders in about a week before the price increase, and it really pushed out the delivery times quite far.
Don't wait too long, now is the time to order. Thanks ! :)
SHELL MODEL: Now = $ 8295.00 (After Dec. 1st = $ 8,695.00)
SWIFT: Now = $ 14,095.00 (After Dec. 1st = $ 16,095.00)
EAGLE: Now = $ 14,095.00 (After Dec. 1st = $ 16,095.00)
FLEET: Now = $ 14,495.00 (After Dec. 1st = $ 16,495.00)
RAVEN: Now = $ 14,495.00 (After Dec. 1st = $ 16,495.00)
HAWK: Now = $ 14,495.00 (After Dec. 1st = $ 16,495.00)
GRANDBY: Now = $ 14,695.00 (After Dec. 1st = $ 16,995.00)
FLEET FLAT BED: Now = $ 21,495.00 (After Dec. 1st = $ 23,495.00)
HAWK FLAT BED: Now = $ 21,995.00 (After Dec. 1st = $ 23,995.00)
GRANDBY FLAT BED: Now = $ 22,495.00 (After Dec. 1st = $ 24,995.00)
Items that were “Optional” before, but now will be “Standard Features” included in the new base prices would be . . .
JACK BRACKETS – STEEL (White) = These will now be “Standard Equipment” and will be installed on ALL Campers (included in the base price) -- unless noted by the dealer or customer not to install them.
ALUMINUM JACK BRACKETS = These will still be “Optional Equipment” and the price will be changing from $ 100.00 up to $ 150.00
ICE BOX = This Item Will Be Discontinued
SMALL REFRIGERATOR 1.9 cu.ft. (3-Way, AC/DC/Propane) = This will now be “Standard Equipment” and will be included standard in all new camper (Except Shell Model) as part of the Base Price.
CAMPER BATTERY SYSTEM = The 1st camper battery, battery box, & battery separator will now be “Standard Equipment” and will be included in the new base price (All Camper Models EXCEPT the Empty Shell Models).
If the customer is ordering a “Shell Model Camper” they will still have to add the Camper Battery System and the 2nd Camper Battery if they want them.
SMALL OPENING DRIVER’S SIDE WINDOW ON GRANDBY MODEL = This will now be “Standard Equipment” and will be included standard in all new Grandby Models, (Except Grandby Shell Model).
ACCESSORY CABINET (Front Driver’s Corner of a Grandby Model) = This Item Will Be Discontinued
NEW OPTIONS PRICING FOR ITEMS HAVING A PRICE CHANGE (Up or Down):
LARGER NORCOLD 3-WAY REFRIGERATOR/FREEZER (AC/DC/Propane) = New Price will be changing from $ 1095.00 down to $ 795.00
SMALL 2-WAY COMPRESSOR REFRIGERATOR/FREEZER (AC/DC) 65L = New Price will be changing from $ 990.00 down to $ 690.00
MEDIUM 2-WAY COMPRESSOR REFRIGERATOR/FREEZER (AC/DC) 80L = New Price will be changing from $ 1190.00 down to $ 890.00
LARGER 2-WAY COMPRESSOR REFRIGERATOR/FREEZER (AC/DC) 110L = New Price will be changing from $ 1390.00 down to $ 1095.00
“SHELL MODEL” FURNACE SYSTEM (Cabinet, Furnace, Thermostat, Propane Tanks) = New Price will be changing from $ 995.00 up to $ 1495.00
TWO BURNER PROPANE STOVE (w/ shell model furnace system) = New Price will be changing from $ 295.00 up to $ 395.00
DSI HOT WATER HEATER W/ OUTSIDE SHOWER = New Price will be changing from $ 780.00 up to $ 795.00
OUTSIDE SHOWER FIXTURE ONLY (NO HOT WATER HEATER) = New Price will be changing from $ 195.00 up to $ 250.00
FLUORESCENT INTERIOR LIGHTS = This Item Will Be Discontinued
FIAMMA 8’ SIDE AWNING = New Price will be changing from $ 795.00 up to $ 845.00
ALUMINUM ROOF RACK = New Price will be changing from $ 295.00 up to $ 395.00
REAR WALL STEPS = New Price will be changing from $ 195.00 up to $ 295.00
LED EXTERIOR LIGHTING PACKAGE = New Price will be changing from $ 250.00 up to $ 295.00 (Not available on Shell Models)
THERMAL PACK = New Price will be changing from $ 475.00 up to $ 575.00
“SHELL MODEL” CAMPER BATTERY SYSTEM = Shell Model 1st camper battery, battery box, & battery separator will still be $ 395.00 - $ 495.00
2nd CAMPER BATTERY = The pricing will be the same to add a second battery as before (the 1st battery is standard w/ base model campers). $225.00
ROLL OVER COUCH/BED – “SHORT BED SHELL MODELS” (Swift, Eagle, Fleet, Raven, Hawk) = New Price will be changing from $ 675.00 up to $ 1195.00
ROLL OVER COUCH/BED – “LONG BED SHELL MODEL” (Grandby) = New Price will be changing from $ 725.00 up to $ 1295.00
SIDE DINETTE COUCH/BED – “SHORT BED SHELL MODEL” (Eagle, Fleet, Hawk) = New Price will be changing from $ 875.00 up to $ 1395.00
SIDE DINETTE COUCH/BED – “LONG BED SHELL MODEL” (Grandby) = New Price will be changing from $ 875.00 up to $ 1495.00
[SIZE=10pt]All of these options will be staying the same / no changes …[/SIZE]
[SIZE=9pt]Mechanical Camper Jacks (4 Corner) $ 695.00[/SIZE]
[SIZE=9pt]Aluminum Jack Extension Plates $ 130.00[/SIZE]
[SIZE=9pt]Swing-Out Jack Extension Plates $260.00[/SIZE]
[SIZE=9pt]Solar Panel - 160 Watt w/ Charge Controller (Roof Mounted) 995.00[/SIZE]
[SIZE=9pt]Solar Panel - 80 Watt w/ Charge Controller (Portable) $795.00[/SIZE]
[SIZE=9pt]Dual Solar Panel Package (Roof 160 Watt & Portable 80 Watt Panel w/ Controller) - $1495.00[/SIZE]
[SIZE=9pt]Forced Air Furnace w/ Thermostat $595.00[/SIZE]
[SIZE=9pt]Fan-Tastic Fan (Power Roof Vent Fan) $295.00[/SIZE]
[SIZE=9pt]Extra Roof Vent $195.00[/SIZE]
[SIZE=9pt]Front Opening Window $195.00[/SIZE]
[SIZE=9pt]Yakima Roof Rack System (tracks, towers, cross bars, locks) $695.00[/SIZE]
[SIZE=9pt]Yakima "Tracks Only" on Camper Roof $340.00[/SIZE]
[SIZE=9pt]Rear Flood Lights – LED $395.00[/SIZE]
[SIZE=9pt]Additional Driver's Side Louvered Window (shell model option) $525.00[/SIZE]
[SIZE=9pt]12 Volt Receptacles (shell model option) $125.00[/SIZE]
[SIZE=9pt]Privacy Curtains (shell model option) $300.00[/SIZE]
[SIZE=9pt]2nd Deep Cycle Battery $225.00[/SIZE]
[SIZE=9pt]Gas Strut Roof List Assists (External Front & Rear) $325.00[/SIZE]
[SIZE=9pt]Flush Mount Glass Top Sink/Stove Upgrade $600.00[/SIZE]
[SIZE=9pt]Smooth Fiberglass Exterior Siding $650.00[/SIZE]
[SIZE=9pt]Silver Spur Package (Interior & Exterior / Black & Grey Design) $900.00[/SIZE]
[SIZE=9pt]Silver Spur Interior Only $500.00[/SIZE]
[SIZE=9pt]Silver Spur Exterior Only $500.00[/SIZE]
[SIZE=9pt]Silver Spur Interior Only "Empty Shell Model" = $ 250.00[/SIZE]
[SIZE=9pt]Side Dinette w/ Swivel Table $500.00[/SIZE]
[SIZE=9pt]Front Dinette w/ Swivel Table (No Inside Shower / No Toliet) $1200.00[/SIZE]
[SIZE=9pt]Front Dinette w/ Cassette Toilet Only $2000.00[/SIZE]
[SIZE=9pt]Front Dinette w/ Hot Water & Inside Shower Only $2600.00[/SIZE]
[SIZE=9pt]Front Dinette w/ Hot Water, Shower, Toilet (Self-Contained) $3200.00[/SIZE]
[SIZE=9pt]Camper Installation w/ Tie Downs & Wiring (most trucks) - $395.00[/SIZE]
[SIZE=9pt]Camper Installation 2005-2015 Tacoma w/ Long 6' Bed - $495.00[/SIZE]
[SIZE=9pt]Camper Installation 2005-2015 Tacoma Crew Cab 5' Bed - $695.00[/SIZE]
Wow!
When looking at the list above, thats a big savings to order now.
Can final payment and delivery be delayed until buyers desired time frame?
I cant seem to find the deposit requirements. Anyone have the skinny on that? Thanks
Bombsight said:
Wow!
Talk to your dealer or Stan. I'm not sure anyone else can answer that.
Thanks.
Anyone have a preference over Prescott, Arizona or Rocky Mountain FWC dealers? Those are the two closest to me since the one in Texas is closing its doors. :cautious:
I am purchasing a FWC 11-18 and a 15% deposit is required; non-refundable. Full payment on delivery of the camper.
Phil
They just opened the Texas dealership, I thought this year. Wow! that's quick.
Sent from my SCH-I545 using Wander The West mobile app
Bombsight said:
Thanks.
I'm in Prescott and ordered through Adventure Trailers here. They are great folks here. I highly recommend Prescott dealer. :D
http://www.adventuretrailers.com/
(I have no experience with Rocky Mountain, but I've heard they are great too :) )
Texas opened on 7/24-7/26. Bummer. New Braunfels looked like a great place.
I believe Rocky Mountain is one of the oldest dealers. Having been a member of WTW for a number of years there have a number of glowing reports. jd
I am a little surprised on the price increase on the seat/dinette and the large reduction $$ of the refrigerator. I was also hoping for a front dinette on the shell model.
Large reduction on fridge maybe the difference between the fridge in base pricing and upgrade to the compressor fridge.
Dan...please let us all know the size, type and brand of battery when you find out...not published that I can find.
Thanks,
Phil
I just got my camper in November. I'm almost sure it is the FP-AGM24-DP
If I have time I'll double check tonight.
Thanks,
Phil
I'm not Dan. But here is what FWC told me was in my Hawk Flatbed I picked up in October. (Too cold and snowy to go out and check personally.)
Exide group 24, 75 amp FP-AGM24DB batteries
