So while I'm replacing my solar controller, I notice the battery isolator relay/solenoid has the Iota 12v + charging lead on one terminal, also on the same terminal is the 12v + truck charging lead and the third lead on the same terminal is the feed for 12v + to the battery. The other terminal has nothing connected to it, the control wiring has not been connected except for a grd wire to the main grd buss. My question is, is this a standard setup?? Looks like they just used the solenoid for a post to connect all the
12v + feeds. Why not use a post terminal? I don't get their logic.
